Lenovo ideapad 110 no power
  • jokophp
    • Dec 2017
    • 39
    • indonesia
    Re: Lenovo ideapad 110 no power
    Mod EDIT: bad advice
    • KvnTM
      • May 2018
      • 434
      Originally posted by jokophp
      try to reball chipset..
      Not the problem here. His problem is on the 5v rail which has nothing to do with the chipset and this laptop doesn't even have one.
      The chipset (PCH) is integrated into the CPU package.
      EDIT: thanks piernov for marking jokophp's response as bad advice.
      • asem18
        • Oct 2016
        • 112
        • my workshop
        Sorry to be late...thank you for all your help...PU401 (3VALW) is ok. My issue is on PU402 ( 5VALW ).
        PU 402 :
        Pin 2 to 5 = 20V is present
        Pin 12 = 3.3v +5VALW_EN is present
        Pin 15 = LDO +5VLP is not presnet ...only 0,635V
        Pin 20 = +5VALW is not present ...only 0,635V.
        I open PJ406 with the inductor soldered to the board and no too = same voltage.
        I desolder and re-solder PU402 = same measure ...no change
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          What about pin9 & pin 17of PU402??
          • asem18
            • Oct 2016
            • 112
            • my workshop
            Pin9/17 = 0V
            • asem18
              • Oct 2016
              • 112
              • my workshop
              #26
              PU401 :
              Pin 9 = +3V_PWRGD = 0V
              Pin 13 = 0,653v....PC411 = 0.653 ( from the side of pin13 ) , and 3.3V from the other side
              • KvnTM
                • May 2018
                • 434
                PU401:
                Pin 9 should be 3.3v if it's not active low.
                Pin 13 is fine. It is the feedback signal which is ac coupled. Thats why you get 3.3v on one side and 0.653v on the other side of PC411.
                PU402:
                Replace the chip. I highly suspect that it is dead.
                VCC pin (17) is odd. It is marked VCC and goes to gnd via a cap. Not quite sure what's the deal there. It is marked +5V_VCC but that rail exists nowhere in the schematic.
                Can you take a closeup picture of PU402?
                Sadly there are no datasheets available for both PU401 and PU402.
                • asem18
                  • Oct 2016
                  • 112
                  • my workshop
                  #28
                  • KvnTM
                    • May 2018
                    • 434
                    Those two components look kinda burned.
                    Also have you tried resoldering PU402 & PU401? The soldering doesn't look very trustworthy in my opinion.
                    Reflow them with a lot of flux. If this doesn't work I'd resolder them with lead free solder.
                    Everything seems to be fine. Either the soldering is bad or both chips died.
                      • 20807
                      PL402 should be 3.3µH according to the schematic .
                      • KvnTM
                        • May 2018
                        • 434
                        He didn't mention that he replaced that inductor. I didn't even pay attention to it but that could be an issue. 1.5uh is definitely too low if he replaced it.
                          • 20807
                          It is to low,so feedback won`t work as it should.I agree with KvnTM about the soldering, need more flux.
                          EDIT: feedback should be ok,my mistake. 1.5uh (according to LA-C341P schematic) is rated at 6A whereas the 3.3uh is rated at 6.5A .
                          • asem18
                            • Oct 2016
                            • 112
                            • my workshop
                            #33
                            KvnTM and SMDFlea..a big thank for your help....no i didn't change inductor,as i told U before this mobo is coming from another reapir shop..ok i m gonna reflow both of them with a lot of flux...ok i will change the inductor with one 3.3µH
                            • KvnTM
                              • May 2018
                              • 434
                              Yes.. I remember you said that it came from another shop.. I forgot.
                              They probably screwed that area up. Resolder both chips and replace the inductor.
                              I can remember that pu402 was getting really hot? This may be due to the wrong inductor.
                              • asem18
                                • Oct 2016
                                • 112
                                • my workshop
                                #35
                                Hello , i resolder PU402 & PU401 , i replace inductor with another one...same issue no 5Valw...and for Pu 401 3Valw is present but no +3V_PWRGD on pin 9.
                                maybe Pu402 is bad !
                                i will change it ..thank you for all your help
                                • KvnTM
                                  • May 2018
                                  • 434
                                  Just replace both chips if you already have to order one. The 3.3v chip is also not working correctly... PGOOD is missing from it.
                                    Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                    09-07-2024, 05:20 AM
                                    Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 05:00 AM
                                    Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
