820-3330 Won't boot
  • barry101
    • Aug 2019
    • 61
    820-3330 Won't boot
    I have a 2012 MacBook Pro in great cosmetic shape that I just acquired and am working on. Logic Board is 820-3330. No signs of water damage. Appears to be good battery.
    Initial symptom was it wouldn't boot reliably. Once in a while it would successfully boot to desktop with no display issues but shutdown shortly thereafter. Sometimes it would start booting and progress bar would advance very slowly and never complete. System had green light on charger and slow fan spin. No chime or mouse LED when it doesn't boot.
    SMC reset seemed to work (LED on charger changed color). These occasions usually occurred when the system was first powered on after being off overnight and then only once until off overnight again.
    I noticed board getting hot on side opposite U1800 PCH.
    Then, while trouble shooting (I believe I was probing around U7400 pins 27 and 28 at the time but that may be a coincidence), things got worse. Lost green light on charger.
    Had to change R7005 (20K) which brought back green light but still had no PPBUS_G3_Hot. Replaced U7000 and Q7030 and Q7035. However, instead of 0.46V (diode mode) on Q7030 pins 1,2,3 and Q7030 pin 5, I only get .001 V. Resistance on this line is 1.2 ohms to ground. Removed U7000 and still got same readings. Replaced again and same readings.
    Fuses on that line are good.
    Looked at all places this signal goes and can't identify any obvious shorts to ground. Reluctant to power the card on given these readings.
    Even if I solve this new problem, I still have the original problem to work out.
    I am beginning to suspect the board is not repairable (could U1800 have gone bad?) and I may need to sell the unit for parts.
    Suggestions?
  • Gimi
    • Aug 2015
    • 75
    Re: 820-3330 Won't boot
    Replace u7400
    • privato89
      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
      by privato89
      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
      Let's begin:
      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
      03-26-2024, 06:37 AM
    • hinisa
      Xiaomi router freezes at boot after re-capping
      by hinisa
      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
      07-08-2023, 05:58 AM
    • Luke Anders
      Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
      by Luke Anders
      A few details about the laptop itself:
      Name: Lenovo Legion 5
      Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
      BIOS Version: GKCN60WW
      EC Version: GKEC65WW
      Serial Number: PF39AQ7Z
      Board Model: NM-D562 Rev 3.0
      RAM: 16GB Installed, DDR4 (brand new)
      NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
      I bought this laptop recently from eBay as a faulty device....
      10-12-2024, 05:13 AM
    • NolesFan
      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
      by NolesFan
      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
      10-24-2024, 06:36 PM
    • torchzack
      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
      by torchzack
      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
      08-28-2023, 07:42 AM
