HP Pavillion 15-p035nd no power
  • aquacattt
    • Oct 2019
    • 7
    • The Netherlands
    Hello guys.
    I am trying to repair a HP Pavillion 15-p035nd, which has no power. I have a 19v rail, but no 3.3, or 5 volt.
    In the picture you see me point at a component, where 19 volts goes in left, and 0.0v on the right. Also, on the mosfet above, input is 19v but no output. Output is also shorted to ground.
    Does anyone have an idea to fix this?
    Greetings,
    Gerben.
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: HP Pavillion 15-p035nd no power
    That’s a capacitor one side is ground other side you get power check your power button if it’s having 3.3V
      • 20707
      Post the motherboard part number,it might be next to the memory slots and will be something similar to DAY23AMB6C0
      • aquacattt
        • Oct 2019
        • 7
        • The Netherlands
        Hello guys,
        The motherboard now does not get any power, it seems to not be able to recognize the charger correctly, it bounces between 0.45v and 0.59v. The charger also makes a high squeaking noise. Charger works correctly on another laptop.
        The board did not make any 3.3v or 5.5v, so was unable to test that.
        Around the memory slots was this:
        tpt MV-0 20 94V-0
        PEMLB028J7LPW
        766473-501
        DC14A0
        Model: Y11A
        • Techtiger
          • Oct 2014
          • 1601
          • france
          In the post#1 you have said +19V +5/3V but now no voltage where did you test in MB , your +19V is short to GND
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Take a pic of the MB both sides upload
            • aquacattt
              • Oct 2019
              • 7
              • The Netherlands
              No, I said i did have 19v, but no 5 or 3 volt.
              Edit: I desoldered a diode, after the 19v short to ground appeared, to no avail. https://www.youtube.com/watch?v=ki708kDH81s
              • Techtiger
                • Oct 2014
                • 1601
                • france
                There is a burnt mark on this MOSFET it's 30V N or P Channel Fet
                • aquacattt
                  • Oct 2019
                  • 7
                  • The Netherlands
                  Oh my lord thank you so much! What kind of mosfet can I order? Should I get a N or P channel fet
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    Just next to the Fet if it is mark as PQ20 as for the Schematic it’s N-channel 30V
                    • aquacattt
                      • Oct 2019
                      • 7
                      • The Netherlands
                      Alright thanks, i'll order this one: https://www.reichelt.nl/power-mosfet...?&trstct=pol_6
                      • aquacattt
                        • Oct 2019
                        • 7
                        • The Netherlands
                        Hey guys,
                        So i replaced the mosfet. I do have 19v again now, but still have the same problem. Left pin 0 volt. Right pin should be ground right?
                        Do you have any other idea about what it can be?
                        Greetings,
                        Gerben van Dijk.
                        • digitalpc
                          • Jun 2016
                          • 305
                          • .DLL
                          any coil shorted to ground?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            The best thing to do is remove the B+ resistor and check which side is shorted to gnd and then apply 1V on the shorted side and see if anything heats up. Post measurement in resistance mode on all coils.
                            • Techtiger
                              • Oct 2014
                              • 1601
                              • france
                              Originally posted by aquacattt
                              Hey guys,
                              Greetings,
                              Gerben van Dijk.
                              you replace a N-Channel fet SOURCE DRAIN GATE no Ground pins go through Youtube/Googel ect how the Fets work without basic knowledge you will do more damage to the MB , upload a pic of MB how you replace fet Q20 , put the multimeter in DIODE mode and test GATE & SOURCE
                              • digitalpc
                                • Jun 2016
                                • 305
                                • .DLL
                                haha same problem with same motherboard ecxatly, do u fix yet?
                                • GLISIT
                                  by GLISIT
                                  01-16-2025, 02:29 PM
                                • playit
                                  450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
                                  by playit
                                  hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
                                  09-02-2023, 02:43 AM
                                • tony359
                                  Global AC logic output - XP Power FleXPower
                                  by tony359
                                  Hi all
                                  I've fixed a couple of FleXPower X7 power supplies. Since they have some logic outputs, I went to test them to make sure all was in order.
                                  "Fan Fail" would work when the fan is manually stopped.
                                  "Global DC" would change state when I manually adjusted one rail beyond 10%
                                  "Global AC" doesn't seem to do anything. To test, I power up the PSU and then I remove power. The 5VSB and Aux rails remain active for quite a few seconds after power is removed. I see the rails collapsing but there is no change in the "Global AC"...
                                  06-20-2025, 03:06 PM
                                  09-06-2024, 05:59 AM
