BIOS Programmer via keyboard or usb?
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    hello everyone any suggestions for bios programmer advanced
    i've seen before in forum a programmer with which I can reprogram the bios via the keyboard, usb and many diferent conectors.
    Any help?
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: BIOS Programmer via keyboard or usb?
    BIOS and KBC programmers are two different things. For one you need CH341A, Raspberry Pi or something like that.
    For KBC you need https://ioprogrammer.com/ or something similar.
    • STKR123
      The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
      by STKR123
      Greetings badcaps community,
      I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
      So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
      Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
      I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
      These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
      I learned that desoldering...
      10-29-2024, 06:03 AM
    • hotcrossedbuns999
      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
      by hotcrossedbuns999
      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
      3. I could only locate two chips that look like bios chips. Could someone verify this
      01-03-2025, 12:32 PM
    • NotEnough
      Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
      by NotEnough
      I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
      What I've Tried So Far:
      • Reseated the cables.
      • Reinstalled AWCC and AlienFX services.
      • Attempted BIOS downgrade but no improvement.
      • Inspected ribbon cables for damage.
      • Explored the possibility of BIOS or
      10-19-2024, 01:34 AM
    • zlr8r
      looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
      by zlr8r
      looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
      cheers
      Dell Inspiron 17 (7786) Laptop
      Service Tag: 5J0NHT2
      Bios: 1.9.0
      MOBO: RO 15 17 WHL 2GB MB / 18706-2
      Attached;
      1. My saved bios using a programmer
      2. Dells Bios updater .exe (v1.16)
      3. Dells Bios recovery file
      4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
      5. Image of ME...
      12-18-2023, 03:08 PM
      by Vesko356
      08-11-2023, 03:27 AM
