HP Elitebook 820 G2 - BIOS LOCATION
  • carlucci
    • Aug 2012
    • 50
    • Moçambique
    Hello, I have a laptop (HP Elitebook 820 G2) on my workbench that came from another computer repair shop and they messed it up.
    They changed the BIOS chips, I can't find the electrical diagram of this motherboard, so I come to ask you, if you can tell me what is the bios chip "model" located on U365 and U366 ?
    Thank you.
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: HP Elitebook 820 G2 - BIOS LOCATION
    main is W25Q128FVSQ.
    This is flash chip support list written in my dump:
    20BA18h
    C22018h
    EF4018h
    1C7018h
    C84018h
    Not sure about EC bios model tho.
    • carlucci
      • Aug 2012
      • 50
      • Moçambique
      Hi. Thank you for you answer, but I mean, in the board where is located the main bios? in U365 or in U366 ? because someone change the chips.
      • carlucci
        • Aug 2012
        • 50
        • Moçambique
        Hello ?!? anyone please.
        • marcin02152
          • Oct 2014
          • 134
          • Polska
          hi
          main is U365 (25L12873F), EC is U366 (25Q16DVSIG)
          • Mr.customer
            • Jan 2021
            • 5
            • australia
            what is the original main chip and original EC ?
            • stingerchamp
              • Sep 2020
              • 425
              • Pakistan
              Two bios chips
              One near PCH called main bios
              One near EC called EC bios , generally we programme KBC
              In some boards
              Only one chip PCH near
              EC bios embedded inside EC
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • STKR123
                The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                by STKR123
                Greetings badcaps community,
                I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                I learned that desoldering...
                10-29-2024, 06:03 AM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • Guest
                Elitebook 850 G5 BIOS bricked
                by Guest
                I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                I assume the BIOS update failed, so I searched for the BIOS chip.
                I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                Can the corrupted...
                03-24-2025, 01:21 AM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
