820-00165-A logic board MacBook Air
  • mferna14
    • Jun 2018
    • 1029
    Just received a 820-00165-A logic board, liquid spill on it. I cleaned very well (ultra sonic cleaning). Turned the logic board on & at once the display fuse F7700 blew (BURNT). I saw green stuff on the LCD connector J8300 (pin 3 & 4). As it was corroded & backlight related., On the safe side I replaced U7701, the fuse & the connector. Again turned on the fuse did not blow, the logic board turned on & I get all the voltages, but as soon as I see the backlight on the LCD screen the logic board turns off by itself. I Checked the vollatge 3.3V & 8.52V on F7140 is present but the 5V rail on L7520 is not present at all. Then again I put the Magsafe jack, turns on fine, fan spin well but after few minutes it just shuts down. VIN is present on chip U7501 8.5v on pin 23. Any tips will be greatly appreciated. Thanks in advance.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-00165-A logic board MacBook Air
    Shutting down with LCD disconnected too? Tried known good Magsafe, DC-in board, DC-in board FFC?
    Always take note of the affected area before cleaning.
    • mferna14
      • Jun 2018
      • 1029
      Yes, the logic board shuts down even if the LCD harness cable is not connected. I am trying with know good part by replacing them but no luck, its shut down. I took a note of all the corroded components & viewed under microscope but no broken trace or such, all connections & soldering seem to be good.
      • mferna14
        • Jun 2018
        • 1029
        Ok., I figured out why was it shutting off automatically after a few moments. Actually there was a slight corrosion on the BIOS chip too & the pin 5 trace was broken to the resistence. Upon a cleanup & installation of the BIOS chip from a donor board, all works fine & does not shut down any more. I installed it in the unit with its SSD, it OS boots up half the way & hangs up. Even with my know good OS it does the same, just hangs up after half OS boot. Any reason why, or any tips on this, do you think the BIOS chip from the donor is bad??? Thanks for all the help anyways.
        • piernov
          • Jan 2016
          • 4437
          • France
          You have to clean ME region.
          • mferna14
            • Jun 2018
            • 1029
            Thanks I will do so...
            • mferna14
              • Jun 2018
              • 1029
              I did the ME Region clean.... I got the clean BIOS program from Badcaps site. Now what happens, I get all the Voltages, CPU core 1.5, 3.3, 5V & all, I observe that the CPU is running in the background as it get hot but still there is no fan spin & no display. I get 5V on pin 1 of J6000. Have I missed certain rail voltage which I have not come across? Your help will be much appreciated. Thanks
              • piernov
                • Jan 2016
                • 4437
                • France
                I'm confused. You said it was turning on but it was hanging while booting macOS.
                • korben_dallas
                  Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                  by korben_dallas
                  Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                  I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                  I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                  MY QUESTION:
                  I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                  02-14-2024, 12:23 AM
                • tony359
                  2007 Macbook logic board fault
                  by tony359
                  Good day all,
                  I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
                  Once the fan was swapped, I installed an OS and it worked fine.
                  The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
                  Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
                  If I see that right, I have missed VCORE on L7100 (page 59)....
                  01-23-2025, 06:59 AM
                • ledbylight
                  M1 A2337 Macbook - No Display, likely due to logic board
                  by ledbylight
                  Hi all!
                  This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                  I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                  11-04-2024, 06:36 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
