e5-471g no power charge led only
  • p7comuter
    • Mar 2015
    • 75
    • Philippines
    pls help my board id is da0zq0mb6e0 rev e core i5 with nvidia gpu
    it shows only charge light..3v and 5v ok..power button 3v..already program bios still the same..anyone encounter this kind of trouble? pls help
    pls upload also working bios dump.
    • 21948
    Re: e5-471g no power charge led only
    You should ask for bios dumps in the Bios Requests sub-forum, or use the forum search.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      check pin 112(RSMRST#) , pin 86(LID#) , PIN 3/11/26/74(for kbc power input), pin 120(DNBSWON#) , pin 125(NBSWON#) of kbc IT8587.
      • p7comuter
        • Mar 2015
        • 75
        • Philippines
        C676 and d17 is ok tried to pull out,,still that part with mark is shorted to ground..why? help pls
        • p7comuter
          • Mar 2015
          • 75
          • Philippines
          i think i found the problem,,the sio pin # 3 is shorted.
          i think its time to replaced sio chip..is there anychance or way..
          can i disabled pin no 3? is there any chance to run without replacing sio chip?
          C263 CAPS IS GOOD
          • p7comuter
            • Mar 2015
            • 75
            • Philippines
            check pin 112(rsmrst#) , pin 86(lid#) , pin 3/11/26/74(for kbc power input), pin 120(dnbswon#) , pin 125(nbswon#) of kbc it8587.
            thank you
            • ipatch
              troubleshooting microsoft surface pro 4 no power no led charge light
              by ipatch
              hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
              10-05-2023, 11:59 AM
            • proxneo
              iPad A2197 no power, A10 and other IC become warm, only 0.5A charge
              by proxneo
              Dear reader
              TL;DR: iPad not turning on, A10 and power IC become (very) warm when attempted to turn on but this power-on cycle has a 'cooldown' period wherein powering on doesn't work, does not take more than 0.5A charge.
              I am working on an iPad 7th generation 2197 from >2019 with no / limited charging and no boot issues. It is a refurbished purchase made in 2021. It appears the 'refurbish' company has either done prior motherboard work (all protective component shield layers are gone) or is one of the many trash refurbish companies (little screen adhesive left, component...
              12-01-2023, 04:14 AM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • GLISIT
              by GLISIT
              01-16-2025, 02:29 PM
