HP N91 motherboard - 3V_S5 short to ground and CPU hot
  • mattpd
    • Oct 2012
    • 301
    This is an HP all in one, but basically a laptop.
    Pretty sure the CPU is dead but I am looking for a sanity check from someone with more experience.
    Dead except for the LED that indicates power adapter is plugged in.
    3v_s5 rail is fully shorted to ground. Removed PL22 and the short is on the 3v_AUX_R side.
    I injected 3A into the rail and didn't find anything hot at first but then took the CPU heat sink off and found that the CPU was getting rather hot. The CPU has two dies, and it's the smaller die that is getting hot.
    Attaching schematics here. Can someone take a look? Page 15 is relevant. Is there any other reason for the CPU to be heating up other than a short inside of it?
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: HP N91 motherboard - 3V_S5 short to ground and CPU hot
    if it's 3V_S5 short to GND this voltage goes all over the MB SOC CPU all in one 3V_S5 required by PCH & CPU power ect you have to narrow down the 3V_S5 you can remove PJP10 PJP12 for example test all PL coils for resistance to GND
    • mattpd
      • Oct 2012
      • 301
      I don't think the "PJP" markings are actual components. In the area of the board where they are marked there is just a via.
      • piernov
        • Jan 2016
        • 4435
        • France
        Smaller die of the CPU package is PCH. If it's heating up when injecting voltage on 3V rail, it's dead.
        • mattpd
          • Oct 2012
          • 301
          Thank you for the confirmation.
          • NEUTRONS
            • Apr 2020
            • 7
            • ALGERIA
            Salut , ta remarque est intéressante, je me trouve peut être dans la même situation avec un hp 250 G5 , je ne trouve pas le schéma de la carte mère, BDL50 LA-D704P Rév: 4: 0, que dois je faire pour m'assurer que le cpu est mort , en court circuit quoi
            merci d'avance
            • playit
              450watt power supply 5v, 3.3v short to ground wire,in output rail ,connectors
              by playit
              hello everyone , working zebronics power suply 450 watts , 5v ,3.3v givin short to ground black wire, also in circuit at output, resistor was charred but shows right values , after removing resistors 39ohms, 51 ohms, there was no short , no continuity beeps with ground , but after replacing new resistors (now i am not switching it on) ,again short still exists . when i put bigger ohm resistor like 100k ohm , no short beeping sound comes , lower ohm resistor gives continuity beeps ,other big ones donest , as its a working psu , i am confused what to remove now or how to go further now .
              09-02-2023, 02:43 AM
            • Victor Moreira Silva
              Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
              by Victor Moreira Silva
              I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
              Well, my decice specs are the following:
              Model: Acer Nitro 5 AN517-54-55T5
              CPU: Intel Core i5-11400H
              GPU: NVIDIA GeForce GTX 1650
              Motherboard: GH51G LA-L181P Rev:1c
              The symptom:
              When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
              05-26-2025, 10:49 AM
            • JimMc0
              Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
              by JimMc0
              Hi there,
              I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
              The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
              03-27-2024, 08:36 AM
            • Geeker007
              9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
              by Geeker007
              Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
              I am new to electronics repair, so my queries could be naive but I am ready to learn.
              So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
              01-28-2025, 03:31 PM
            • grimacelord
              Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
              by grimacelord
              Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
              After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
              I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
              10-24-2024, 12:31 PM
