The battery reach the full charge, if the system is in idle state or with no hard processes, the machine stays on. If I play a game with battery only , after a couple of seconds the system shut down immediatly. the same thing happened when I used a 120W power supply even with the battery connected. Testing with a 220W power supply the system works very well. So I was wondering if a battery that arrives at the right charge and doesn't drain quickly will create a problem like this?
ROG G751JY battery problem
Tags: None
Re: ROG G751JY battery problem
Yes it can be a bad battery. I've seen "new" batteries do this as well, turning off under load.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
You think there is a component inside the battery
That I can check ? Is it interrupted inside the battery or via the charging chip?Comment
by ahmarzoI have acer laptop tmx314-51 with part no 6050A3020501.
The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
The schematic is not available... -
Dear all,
i have the above laptop which had a problem with battery. i replaced it with a compatible one..
the laptop DOES NOT POWER ON..
with it old battery it does power on.
i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
when i shutdown the laptop does not power on.
does anyone have any solution!
when is not power on the usb c voltage tester shows 5v 1.3A
when i disconnect battery and power on and then connect battery the tester... -
by mferna14Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
by String2016I have this acer V3-472 laptop with board id DA0ZQ0MB6E0 REV:E , With battery charging problem, At first I thought it was a bad battery so, I bought new battery but the problem still the same,cannot turn on with battery only and when battery and charger plugged in no orange light indicator but the laptop is working properly with charger only plugged in. here is the measurement.I noticed when battery and charger both plugged in the voltage on current sense resistor PR1 is fluctuating form 19v go down but when charger only plugged in its working fine here is the measurement of PU1 BQ737 when battery...
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
- Loading...
