GL502VM Rev. 2.1 Keyboard Problem [SOLVED]
  • lazaro.089
    • Jun 2014
    • 85
    • Mexico
    Hi Everyone!
    I have an Asus ROG Strix GL502VM (the mohterboard says GL502VM Rev. 2.1 but it has an i7-7XXX Proc. so I think it actually is GL502VMK idk...)
    The problem is with the keyboard. The power button works but every other key doesn't.
    What I tried:
    -Check the keyboard with Vertyanov Keyboard tester (Everything seems fine)
    -Re-programmed the EC chip ITE8171FN-56. (Didn't work, flashed ok but verification failed every time at 82%.)
    -Replaced ITE8171FN-56
    -Reprogrammed new ITE8171FN-56. (It flashed and verified ok but keyboard still dead)
    I don't know if I need to check the main BIOS, maybe Main Bios is rewriting EC Section on boot to the ITE8171FN.
    Any ideas?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: GL502VM Rev. 2.1 Keyboard Problem
    Do Touchpad and USB keyboard work fine with this laptop?
    • lazaro.089
      • Jun 2014
      • 85
      • Mexico
      Yes, they work fine.
      Keyboard is dead even in BIOS.
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        are you sure you used the correct file for the keyboard controller?
        • lazaro.089
          • Jun 2014
          • 85
          • Mexico
          I used one downloaded from Vinafix.
          I haven't found any other
          I think it can be extracted from the main bios but i don't know how.
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            I asked you this question because I asked for info on Vxxxxxx and the CEO did not know how to give me more info. I'm not sure, but I think that like ME, it programs itself automatically after programming the bios.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Post your bios backup here.There are enough experts here to extract EC from main bios.
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                The problem (for me) is understand how this system works.
                This notebook (gl502 series) has two ITE chips, the first is the IT8171FN-56 / BX for the keyboard and can be programmed via the keyboard port, the other IT8995VG-128 / CX has a dedicated port for its programming. I wanted to understand where its firmware is stored and if it has an internal memory, etc
                  • 21203
                  Edit:looking at wrong boardview
                  • jasko_jacker
                    • Oct 2014
                    • 1137
                    • italy
                    Do you mean my card compared to the GL502VM model? , this and the gl502VSK have the same chips but positioned differently, and some components have the same identifier. I think the working principle is the same.
                    • lazaro.089
                      • Jun 2014
                      • 85
                      • Mexico
                      Sorry for the late response, I took off the weekend.
                      Here is my main Bios dump
                      I'm also wondering this. I have a board view but doesn't have an schematic.
                      • lazaro.089
                        • Jun 2014
                        • 85
                        • Mexico
                        I flashed the Main bios with
                        https://www.badcaps.net/forum/showth...658#post843658
                        But still no working keyboard.
                        I think the firmware is stored in IT8995VG-128 but I don't know how to program.
                          • 21203
                          Its the ITE8171 that gets programmed by a vertyanov programmer
                          GL502VM IT8171 KB_pins=30 LEFT DOWN FLASH=56 PD0=29 PD1=20 PD2=15 PD3=23 PD4=14 PD5=16 PD6=12 PD7=30 BUSY=26 STB=18 AFD=28 INIT=21 SLIN=19 KSI4=22 KSI5=24
                            • 21203
                            [QUOTE=lazaro.089;916709]Sorry for the late response, I took off the weekend.
                            Your bios backup isn`t proper. Make another backup and post it in the other thread of yours in the bios requests.
                            • lazaro.089
                              • Jun 2014
                              • 85
                              • Mexico
                              Ok then I think I'm screwed, I didn't pay attention and the dump failed.
                              And I already overwritten the Main bios, It does boot tho, but I'm pretty sure it isn't the model because inside the bios it shows GL502VMZ
                              What should I do now?
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Look at post#4 in https://www.badcaps.net/forum/showthread.php?t=67696 for GL502VM rev 2.1 bios.
                                • lazaro.089
                                  • Jun 2014
                                  • 85
                                  • Mexico
                                  Thanks! @mcplslg123
                                  I have the correct dump thanks to @SMDFlea.
                                  And I'm back to square 1. (At least I have the right dump)
                                  Now, I'm trying to flash the EC, Trying with 8171 I only can flash 56K of the EC Dump.
                                  So, I tried programming the IT8995 (I took precautions and this time dumped correctly before flashing)
                                  I did flash the EC IT8995 with success. But I keep having the keyboard problems.
                                  I'll check the boardview to track down the connections but I really think is firmware related. Because some dumps I try with IT8171 resulted in CapsLock led always on and others shut it down.
                                  Any ideas what should I check next?
                                  UPDATE:
                                  I found out that Main Bios DOES rewrite the EC Bios after first boot.
                                  • lazaro.089
                                    • Jun 2014
                                    • 85
                                    • Mexico
                                    SOLUTION
                                    I finally found a solution for the keyboard problem.
                                    I found the Asus Keyboard Adjustment tool, extracted the .exe file and inside the ./.rsrc/1028/BINARY directory are located 4 56k sized FW_NK000XXXXX files.
                                    These are different keyboard firmwares that can be flashed to IT8171fn-56.
                                    For the GL502VMK board I used FW_NK0003000B and flashed it with Vertyanov.
                                    I'll post these files as attachments for anyone that has the same problem.
                                    PS. Can a mod mark this post as solved? I couldn't find the solved option.
                                    https://www.badcaps.net/forum/showpo...9&postcount=15
                                      • 21203
                                      Thats a great fix. Can you post the IT8995 and other dumps into the your bios request post . https://www.badcaps.net/forum/showthread.php?t=79528
                                      • jasko_jacker
                                        • Oct 2014
                                        • 1137
                                        • italy
                                        Re: GL502VM Rev. 2.1 Keyboard Problem [SOLVED]
                                        • MrDadosz
                                          Lenovo Legion 15IMH05 keyboard problem
                                          by MrDadosz
                                          Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
                                          When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
                                          In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
                                          Shortcuts Fn + F1-F12 are working. Keyboard is fine.
                                          I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
                                          08-15-2024, 05:07 AM
                                        • fmajbour
                                          Acer Nitro 5 model A515-51 keyboard problem
                                          by fmajbour
                                          I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                          Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                          i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                          I have check the keyboard connector on the mainboard every thing looks ok.
                                          Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                          I need your advice if anyone face...
                                          11-13-2023, 09:50 PM
                                          HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                          09-06-2024, 06:21 AM
                                          HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                                          HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
