Asus Rog Strix GL502VM EC Bios Needed
  • lazaro.089
    • Jun 2014
    • 87
    • Mexico
    Hi I'm looking for the EC BIOS to flash an IT8171FN-56
    My Keyboard doesn't work. Replaced the chip but the EC file I downloaded didn't work either.
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Asus Rog Strix GL502VM EC Bios Needed
    try and report
    • lazaro.089
      • Jun 2014
      • 87
      • Mexico
      Same behaivor. Power button works, Caps Lock led on. But no response from any other key.
      The keyboard was checked using Vertyanov Keyboard test mode and every key works.
      Should I flash main bios?
      My thought is: there is a part of EC bios in Main BIOS what if EC is overridden by Main bios during boot?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        EC bios is flashed from main bios on first boot as long as the EC is blank. After that, Ec bios has nothing to do with main bios.
        • Francisco.s
          • 686
          • Spain
          Did you verify the content of ec-bios after first power on?
          If they don't match, probably the data is overwrite during boot as you mention.
          • lazaro.089
            • Jun 2014
            • 87
            • Mexico
            I'll verify that and post the results.
            • lazaro.089
              • Jun 2014
              • 87
              • Mexico
              I flashed Main BIOS too with
              https://www.badcaps.net/forum/showth...658#post843658
              but it has the same results.
              Also verifying the EC BIOS after first boot up, it does have the informations I flashed.
              So maybe wrong EC File?
              • lazaro.089
                • Jun 2014
                • 87
                • Mexico
                So... I screwed up and wrongly dumped my Main bios and now it's gone. Can you guys help me with that too?
                I have another bios file and that one boots but its from an GL502VMZ and it's different.
                  • 21841
                  Try this bios and EC.
                  • lazaro.089
                    • Jun 2014
                    • 87
                    • Mexico
                    Thank you SMDFlea! I'll try them
                    UPDATE:
                    Ok, the Bios works fine, It got back all the features and it says GL502VMK again.
                    But, when I compare the EC file with my dump, the dump is of lower size.
                    I think it is related to the Veryanov parameter of FLASH=56
                    Should I erase that parameter?
                      • 21841
                      Yes try it, or change parameter to 64 and try that.
                      • lazaro.089
                        • Jun 2014
                        • 87
                        • Mexico
                        It gets corrupted if Flash>56 I think>
                        Here is the new dump.
                          • 21841
                          See the attatched picture,your ITE_2.bin is on the left,the 128KB EC i cut from the VMK bios is on the right. Compare the 2 files.At offset E050 the ITE_2 says IT8171-bbk--v1.0 ,itmust be the 8KB bootblock from E000-FFFF.The first dump ITE_.bin is 56KB ,there`s no bootblock, all 3 files compared the same (56KB) from block 0-DFFF .Did you delete the FLASH=56 parameter before you dumped the ITE_2.bin
                          • lazaro.089
                            • Jun 2014
                            • 87
                            • Mexico
                            Yes, ITE_2.bin is with FLASH=64, I also tried removing the FLASH parameter (The default makes FLASH=128) But it has the same results.
                            Also looking at boardview, I managed to dump and program IT8995 with the full EC file.
                            But I also checked that Main bios reprograms it after first boot. (After first boot I compare both dumps and they're different)
                            • volinakis
                              • Jan 2021
                              • 2873
                              • N/A
                              I managed to make keyboard working to a GL753VD following this post:
                              https://rog.asus.com/forum/showthrea...nt-Tool/page12
                              2 issues, tho: Caps lock close display backlight and keyboard backlight is not working. Copy in fw tool folder created any FW_NKxxx and rename it as NK.bin, try with all versions, no need to use other tools to flash EC.
                              • ashefr10
                                • Mar 2021
                                • 11
                                • France
                                HELLO , ok for ME firmware , no ok for backlight keyboard .
                                • Slavol
                                  • May 2015
                                  • 83
                                  • Poland
                                  Here is works firmware for this IT8171 - all keyboard works OK - tested on GL753VD
                                  • jefminguta
                                    • Sep 2023
                                    • 2
                                    • Brazil
                                    I have the same problem, after updating the ROG Strix G513IM keyboard firmware, the keyboard stopped working, only the on/off key works.
                                    You have the keyboard firmware for the ROG Strix G513IM or can you tell me how I could get it?
                                    • peste
                                      • Dec 2016
                                      • 13556
                                      • ROMANIA
                                      see post #15,17, make a copy of the chip before writing...
                                      • DanqeR
                                        • Oct 2014
                                        • 6
                                        • Romania
                                        Tested on Asus GL753VD all ok. Thanks.
                                          ASUS ROG GL502VM-DS74-HID3 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL502VM-DS74-HID3 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VM-DS74-HID3 boardview and GL502VM-DS74-HID3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:08 AM
                                          ASUS ROG GL502VM-DS74-HID8 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL502VM-DS74-HID8 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VM-DS74-HID8 boardview and GL502VM-DS74-HID8 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS ROG GL502VM-DS74-HID11 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL502VM-DS74-HID11 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VM-DS74-HID11 boardview and GL502VM-DS74-HID11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS ROG GL502VM-DS74-HID5 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL502VM-DS74-HID5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VM-DS74-HID5 boardview and GL502VM-DS74-HID5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS ROG GL502VM-DS74-HID6 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL502VM-DS74-HID6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL502VM-DS74-HID6 boardview and GL502VM-DS74-HID6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
