GL502VM Rev. 2.1 Keyboard Problem [SOLVED]
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: GL502VM Rev. 2.1 Keyboard Problem [SOLVED]
    Wow, Good job
    • lazaro.089
      • Jun 2014
      • 87
      • Mexico
      Originally posted by SMDFlea
      Thats a great fix. Can you post the IT8995 and other dumps into the your bios request post . https://www.badcaps.net/forum/showthread.php?t=79528
      Sure! I'll post them there too!
      • cilversoul
        • Dec 2020
        Originally posted by lazaro.089
        SOLUTION
        I finally found a solution for the keyboard problem.
        I found the Asus Keyboard Adjustment tool, extracted the .exe file and inside the ./.rsrc/1028/BINARY directory are located 4 56k sized FW_NK000XXXXX files.
        These are different keyboard firmwares that can be flashed to IT8171fn-56.
        For the GL502VMK board I used FW_NK0003000B and flashed it with Vertyanov.
        I'll post these files as attachments for anyone that has the same problem.
        PS. Can a mod mark this post as solved? I couldn't find the solved option.
        You mentioned you can flash the keyboard firmware for this fix. Is there a process you can point me to that has a guide to making that firmware swap?
        • emestee
          • 228
          Please note that on Asus boards the designations printed on the board silkscreen itself (eg. X01AB Rev 2.0) often mean nothing. The exact model of the board is on the yellow sticker on the RAM slot or similar.
          • pctec
            • May 2014
            • 8
            I'm wondering if anyone could explain about the procedure of keyboard's firmware reprogramming on these Asus gaming laptops. I'd appropriate any help.
            • naser6979
              • May 2021
              • iran
              #26
              I have asus gl702vm. The problem is with the keyboard. The power button works but every other key doesn't.
              I have 2 question?
              1- we know it8171fn-56 is dead. we bought it. if we change it 8171fn-56 , it need program???
              2 - if it need program. for programing need special machanism???
              • f-bone
                • May 2013
                • 96
                • Greece
                #27
                Originally posted by jasko_jacker
                hi guys!
                I have the same problem and also a Vertyanov programmer. I can read/write the ITE chip from the keyboard connector and its a 128kb file. How can I target the 56 chip responsible for the keyboard? I do not understand how to programm that one.
                @jasko_jacker
                • naser6979
                  • May 2021
                  • iran
                  #28
                  I have 2 question?
                  naser6979 is offline
                    • 21853
                    I have 2 question?
                    see here - https://rog.asus.com/forum/showthrea...nt-Tool/page12
                    • reassor
                      • Apr 2021
                      • 181
                      • Poland
                      #30
                      Sorry for reviving the thread but i have a wierd 1.
                      My keyboard is same like other ones - only power works.
                      But its not detected in system (usb descriptor failed thingy)
                      So i cannot flash ec portion of keyboard using KAT from ASUS.
                      Any ideas?
                      GL502 VM rev 2.0 (6th gen)
                      • reassor
                        • Apr 2021
                        • 181
                        • Poland
                        #31
                        When I flashed bios from here and booted w/o battery while mashing f2 keyboard works in bios. But you just restart and it's dead.
                        If you reset bios you can catch it by hitting f2. But if you leave it (w/o) hdd so it goes to bios by it self kB will not work =(
                        I'm at loss here. Do not have EC programmer.
                        • jefminguta
                          • Sep 2023
                          • Brazil
                          #32
                          I have the same problem, after updating the ROG Strix G513IM keyboard firmware, the keyboard stopped working, only the on/off key works.
                          You have the keyboard firmware for the ROG Strix G513IM or can you tell me how I could get it?
                          • questore
                            • Dec 2015
                            • 564
                            • csongrád
                            #33
                            SOLUTION
                            https://www.badcaps.net/forum/showpo...9&postcount=15
                            Can you post details on the vertyanov programming. what configuration is needed for this? is it done trough debug port or KBC? etc.
                            • questore
                              • Dec 2015
                              • 564
                              • csongrád
                              #34
                              SOLUTION
                              What connector did you use? how many number of pin was on the cable? 1.0mm or 0.5mm cable? what was pinout?
                              Can you please post these details for others so they dont have to find out on their own.
                              • MrDadosz
                                Lenovo Legion 15IMH05 keyboard problem
                                by MrDadosz
                                Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
                                When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
                                In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
                                Shortcuts Fn + F1-F12 are working. Keyboard is fine.
                                I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
                                08-15-2024, 05:07 AM
                              • fmajbour
                                Acer Nitro 5 model A515-51 keyboard problem
                                by fmajbour
                                I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                I have check the keyboard connector on the mainboard every thing looks ok.
                                Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                I need your advice if anyone face...
                                11-13-2023, 09:50 PM
                                HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse boardview and 450 G5 + Essential 15.6-inch Case, Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                                09-06-2024, 06:21 AM
                                HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                                HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
