Asus X555LD doesn't turn on
  • atgeek
    • Sep 2019
    • Italy
    I've an X555LD Rev 2 motherboard that doesn't turn on. Checked the power button and it has 3.3V. Also the two near mosfet seem ok. Maybe it's a bad BIOS?
  • peste
    • 13625
    • ROMANIA
    Re: Asus X555LD doesn't turn on
    https://www.badcaps.net/forum/showth...ght=X555LD+Rev
    • atgeek
      • Sep 2019
      • Italy
      Thanks. I forgot to mention that there are no led on too. May it still be a BIOS related issue?
      • Techtiger
        • Oct 2014
        • 1602
        • france
        find out the charge Management IC PU8800 form the Bordview ACOK ACDECT pin 5 & 6 , find out 3V & 5V regulater IC is outing put 3 VAO & 5 VAO for the 2 Coils , Back up your Old Bios Dump
        • atgeek
          • Sep 2019
          • Italy
          Solved by desoldering and reflashing the BIOS. Thanks everyone
          • bajdik
            Asus X555LD after watter damage - won't turn OFF
            by bajdik
            I have a problem with Asus X555LD after watter damage.
            The KBC chip with some traces was damaged.
            I changed KBC chip, repair trace. Laptop works great, but if I turn it off,
            it turn on again. If I put adapter in it, it power on.
            Any idea? Schematic is not available..
            01-11-2023, 02:40 AM
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
          • Scotchmist
            Asus GA502D keeps blowing mosfet
            by Scotchmist
            I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
            I have removed the mosfet and can run the laptop no problem
            The MOSFET is FDPC5018SG
            Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
            08-24-2024, 02:23 PM
          • MicroSMD Lab
            by MicroSMD Lab
            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
            01-10-2024, 06:36 AM
          • someonenotyou
            ASUS G513R - cannot remove MOSFET
            by someonenotyou
            Hi.
            I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
            I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
            Of course, I did not force it, but tried to lift it up with tweezers.
            Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
            10-10-2025, 11:05 AM
