Laptop screen testing simple question
  • IamPritesh
    • Aug 2017
    • 356
    • India
    I have this laptop that comes with a 30 pin paper led. The problem is double image and pink screen at some portion.
    I have a 30 pin normal led screen and another 30 pin 11 inch screen. So the question is can i test using either os these to see if it is a screen issue or motherboard .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Laptop screen testing simple question
    Sure, you can test with the other screens as long as display supports.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      How do I know if display is supported ...is is just the PINS ? or other factors also should be taken into account before using it for testing purpose ?
      I want to thank you for your response.I have another query , could you please take a look at that one as well
      https://www.badcaps.net/forum/showthread.php?t=78922
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        yes, just the pins. you can try attaching another screen with same pins. You will get display if resolution is supported. All screen doesnt support all resolutions-thats what i mean by saying "as long as it is supported"
        • VcemPzd
          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
          by VcemPzd
          Hello everyone !
          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
          04-28-2025, 10:14 AM
        • Stunt
          Hp Laptop Stuck on Hp protected by hp sure start screen
          by Stunt
          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
          screen that's it and stuck there. I left it until the following day and i still...
          09-02-2025, 01:51 PM
        • jean luc ferre
          laptop hp g72 b52sf screen problems
          by jean luc ferre
          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
          06-07-2025, 03:27 PM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • almarhum
          To fix laptop screen vertical line by working on its EDP cable
          by almarhum
          Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
          As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
          05-07-2024, 02:12 PM
