lenove thinkpad t410 hidden light screen
  • mmaewbsoft
    • Apr 2018
    • 64
    • yemen
    working with external desktop screen but with its screen hidden light i checked fuse f1 and f19 in mb getting 3 v and duse on screen 3v i change other screen from other t410 working but frist screen is hidding light
    please hlep me what can i do to solve screen
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: lenove thinkpad t410 hidden light screen
    probably backlit ic on the screen itself is bad or components near it.
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      check fuses on lcd back panel and if any fuse found blown also check caps for short circuit before you replace fuse.
      • mmaewbsoft
        • Apr 2018
        • 64
        • yemen
        fuses good and no components bad i want to know which ic for light screen
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • Rav_tangle
          MacBook Pro 2011 turns on with keyboard light , screen dead
          by Rav_tangle
          Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
          I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
          Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
          is this...
          05-31-2024, 04:09 PM
        • Alicat
          Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
          by Alicat
          Stopped by this site trying to fix my parents Panasonic Plasma TV.
          Model number is TH-50PZ85U
          Power comes on and the red power light stays on solid.
          Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
          I also hear a few clicks.
          I also think my parents said there was a thunderstorm and the TV failed after that.
          Section 6 in the service manual talks about power and no screen,...
          10-30-2024, 10:09 AM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Ihandyrepair
          sony 55X850D black screen no front white or red led light.
          by Ihandyrepair
          Hi guys
          strange one
          I have a dead Sony 55X850D
          when plug in, black screen, no front white or red LED, no back light no screen
          Voltages I get
          3.3v LD/power and main board
          reg 12V
          reg 19V
          3.3v on power on pin
          no Tcon on
          no tcon 12v
          no BL_on
          I do get BL_ERR 2.0v
          I tried to bypass it by ground it but still get same symptom
          I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
          or is possible the chip next to...
          08-07-2024, 04:58 AM
