Dell 3421 motherboard 5J8Y4 does not turn on
  • ruletero
    • Nov 2018
    • 183
    • Mexico
    Hi everyone
    I have 5J8Y4 Dell 3421 motherboard it does not turn on.
    I don't have power led, I checked power secuence and I have 3v alw, 5v alw and It's 3V_5V_POK signal but Kbc does not release PM_RSMRST#.
    I don't know what to do now, Please help
    Raul
    PD: Sorry for my bad English
  • razu
    • Jan 2015
    • 218
    • Bangladesh
    Re: Dell 3421 motherboard 5J8Y4 does not turn on
    reflash the bios, with new file
    • ruletero
      • Nov 2018
      • 183
      • Mexico
      Sorry
      I forgot to say it, the first I do was to flash the bios without change.
      Thanks.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        The kbc itself can be bad-so if you have a spare kbc, replace it first.
        • Luaina
          • Sep 2016
          • 12
          • Madagascar
          First check that the KBC is properly powered (Test all the voltages that goes in it).
          • pyry
            • Dec 2015
            • 37
            • Mexico
            que voltajes tienes en el charger pu4005
            en los pines
            20
            6
            5
            12
            16
            • ruletero
              • Nov 2018
              • 183
              • Mexico
              pin 104 vref 3.27v
              pin 19 vcc 3.19v
              pin 4 vdd 0v ???
              pin 114 vbkup 3.12v
              I guess it is fine...
              • ruletero
                • Nov 2018
                • 183
                • Mexico
                en los pines
                20
                6
                5
                12
                16
                20 19v
                6 2.55v
                5 0v
                12 2.76v
                16 6v
                I guess it's fine too.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Originally posted by ruletero
                  pin 104 vref 3.27v
                  pin 19 vcc 3.19v
                  pin 4 vdd 0v ???
                  pin 114 vbkup 3.12v
                  PIn 4 VDD on kbc must be 3.3V. Measure again and if not present, then you need to find out why voltage not present on pin4. This is the input for kbc-so kbc wont work properly without this voltage.
                  • Luaina
                    • Sep 2016
                    • 12
                    • Madagascar
                    pin 104 vref 3.27v
                    pin 19 vcc 3.19v
                    pin 4 vdd 0v ???
                    pin 114 vbkup 3.12v
                    3.3v Vdd is S0 power rail. It is present only after you press the power button ( It figures among the last volatge that comes in alongside the processor volatge). I recommend replacing the IO but you can nevertheless inject t 3.3v there and see what happen( Does this injected voltage goes down? something hot?).
                    • pyry
                      • Dec 2015
                      • 37
                      • Mexico
                      friend first check that all the signals are reaching the kbc for example
                      feed that we already know is fed
                      pin 99
                      pin 85
                      pin 17
                      pin 73
                      pin 93 to change from 3.3v 0v and go up to 3.3v when you press the power button
                      for that you can bypass pin 4 with the two of PWRBT1 for an instant only and at the same time measure the leg of kbc 93 that the change of state is coming to the kbc of the power button
                      • ruletero
                        • Nov 2018
                        • 183
                        • Mexico
                        I guess that signal is not present en s5 state, but I'll check it again.
                        • ruletero
                          • Nov 2018
                          • 183
                          • Mexico
                          At the moment I am reviewing the S5 status because neither the power led turns on, but thank you very much for the recommendation.
                          • ruletero
                            • Nov 2018
                            • 183
                            • Mexico
                            I'm going to order the KB but, does it need to be programmed? or only I must to change it.
                            Thanks for the help
                            • Luaina
                              • Sep 2016
                              • 12
                              • Madagascar
                              I don't think it's a programmable KB. You have just to replace it.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Yes, schematic clearly tells it S0 state power. so wont be there without turning on.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Thanks for the help
                                  NPCE885 is not programmable-so just replace it and see if RSMRST appears.
                                  • ruletero
                                    • Nov 2018
                                    • 183
                                    • Mexico
                                    Ok
                                    I ordered the chip I have to wait about 3 weeks for arrive it.
                                    Thanks all, I'll inform you the results as soon as I can.
                                    • julianmustofa
                                      Dell 3421 wont turn on with strange behavior
                                      by julianmustofa
                                      Hi all
                                      I've been working on dell 3421 that won't turn on/charge
                                      Specs: i3-3217U no discrete gpu
                                      The behavior is
                                      -won't charge (charging light up for 3 second and goes away)
                                      -won't turn on if both battery + power adapter plugged in
                                      -in other way it can turn on with either power adapter only or battery only
                                      But sometimes all this issue goes away with no clear reason.
                                      Does it indicates faulty board chipset?
                                      08-30-2023, 06:29 AM
                                    • Geeker007
                                      9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                                      by Geeker007
                                      Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                                      I am new to electronics repair, so my queries could be naive but I am ready to learn.
                                      So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                                      01-28-2025, 03:31 PM
                                    • Julian Bailey
                                      Dell Latitude 5350 Ultra 7 Motherboard
                                      by Julian Bailey
                                      Hi
                                      I have a Dell Latitude 5350 Ultra 7 Motherboard I am trying to repair that has a blown chip.
                                      The chip is marked as eHOLH similar to the one I have pictured.
                                      Any ideas what it does and what the pin outs are as 3 tracks have gone and need to find out what / where they went / did etc.
                                      Dell PN of the motherboard is 08DCGW.
                                      Below is the area I am trying to repair:
                                      Does anyone have a picture of this motherboard in this area they could take and upload?
                                      Cheers...
                                      07-03-2025, 11:25 PM
                                    • Bowline
                                      by Bowline
                                      06-11-2025, 10:13 AM
                                    • sourceaxe
                                      Dell Precision 3650 Tower (Desktop motherboard) - Schematic (and board view) request
                                      by sourceaxe
                                      Does anyone happen to have the schematic (and if available also: the board view) for the Dell Precision 3650 Tower motherboard please?
                                      Manufacturer: Dell
                                      Model: Precision 3650 Tower
                                      Motherboard markings:
                                      • IPRKL-RDT REV: A00
                                      • D33D66
                                      • CN-0NDYHG-PE100-1AM-05SY-A01
                                      • P&Q 2134 CM-4 94V-0 E162264
                                      Thank you in advance.
                                      11-21-2024, 05:35 PM
