Need to Edit Vbios on Hex level BGA SWAP Macbook
  • macattack600
    • Aug 2011
    • 97
    How would I know how to edit hex of laptops internal vbios?
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Re: Need to Edit Vbios on Hex level BGA SWAP Macbook
    For what purpose ?
    • macattack600
      • Aug 2011
      • 97
      I changed the GPU from to 7700m from 6770m with rework station BGA pinout exactly the same , I get blackscreen but keyboard lights up ,the job is done right I've done many
      No external monitor tried other case same thing.
      I'm thinking all I need is the AMD7000Controller.kext I have idea how to get to terminal
      • envym
        by envym
        Hi everyone!
        06-27-2025, 08:54 AM
      • Karmet
        MacBook Pro 16" 2019 NAND Swap
        by Karmet
        I couldn't find a post related to this, so if it exists please point me in that direction.
        I have a 2019 MacBook Pro 16" 1TB with a dead embedded NAND. I've seen some information about how it is possible to swap NANDS from certain boards, but it has to be a matching set.
        I have a MacBook Pro 2017 logic board 820-00923-A 1TB on hand that is new in the box. It should be possible to match up the NAND 0, 1, 2, 3 chips and transplant them onto this 2019 board... in theory. Has anyone approached this, or has success in doing this?
        07-24-2023, 10:48 AM
      • Flasman90
        Macbook Pro DFU Restore Issues
        by Flasman90
        I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
        - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
        - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
        08-30-2025, 10:27 AM
      • tobeend
        Bypass mdm macbook m2 ventura
        by tobeend
        1. RESET MACOS WITH IPSW
        a. Power off MacBook, press and hold the power button to enter Recovery
        b. Open Disk Utility, remove Macintosh HD
        c. Reboot, connect to the network to Activate Mac.
        d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
        d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
        e. Release the other keys, but keep holding the Power key for another 10 seconds
        f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
        05-26-2023, 07:18 AM
      • SarcasticOP
        General question about MacBook power rails for repair.
        by SarcasticOP
        I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
        • PPBUS_G3H (12.6V-12.8V)
          • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
        • PP3V42_G3H (3.42V)
          • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
        • PPVRTC_G3H (3.3V)
          • This
        12-12-2024, 05:50 PM
