820-2610 macbook 17” need some help...
  • justin35
    • Jan 2019
    • 149
    • It
    This laptop came in with dim green light, and dead.
    I replaced lm397 responable for adapter sense, now i have green light.
    If i short smc_onoff_l pads, i think the board tries to enter s0 state, i am not sure... but no fan spin
    I measured voltages and i am missing cpuvcore (0.29v)
    The chipset becomes hot in a few seconds...
    I measured cpuvcore to gnd and i have 5.04ohms..
    I don’t know if it’s ok or not... i only had a 15” c2d board to measure cpuvcore to gnd and it’s like 30ohms.
    I replaced u7100 (from donor -unknown condition)
    I found 1 missing cap on cpu isense line and r1004 was missing also...reinstated them
    Stil nothing no fan spin no post no usb nothing
    Thanks!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-2610 macbook 17” need some help...
    Replaced C7771 yet?
    • justin35
      • Jan 2019
      • 149
      • It
      Forgot to mention, no need as the line is 1.1v always...
      • piernov
        • Jan 2016
        • 4439
        • France
        Still a good idea to do it if it wasn't already done.
        Anyway, go down the list of power rails and measure voltages to see which rails come up and which don't when triggering power button. (may be easier to solder a wire on SMC_ONOFF_L and touch it to ground to trigger power button)
        • justin35
          • Jan 2019
          • 149
          • It
          I'll replace it just in case of further failure.
          Will check all the power rails tonight and see which one is missing...
          Thanks again!
          • justin35
            • Jan 2019
            • 149
            • It
            Problem solved!
            It was a damn resistor which enables mcpvcores0 which was desoldered on one tab... probably someone who was there before me dropped something on the board in that area...
            Anyway it was missing mcpvcore which got my attention and this is how i saw the resistor.
            Board boots, chimes, boots from usb dongle.
            It has some other issues but i will fix them next.(no wifi no keybd)
            Again piernov a big thank you!!!
            • justin35
              • Jan 2019
              • 149
              • It
              I can't find anything wrong with wifi 5v line or any other fault on data lines of that connector.
              I tried 3 different wifi boards, still no signs of wifi...
              I do not have the hdd cable, and i am looking to see wifi options in boot menu holding down the option key during startup...
              Should it be visible as for a1278 211-2012 models?
              Any ideea where to look now?
              Thanks again!
              • piernov
                • Jan 2016
                • 4439
                • France
                I may be wrong but I don't think this model can boot over WiFi so I guess it's normal that it doesn't appear on boot menu.
                Boot on an external drive with macOS on it.
                • justin35
                  • Jan 2019
                  • 149
                  • It
                  Well wifi works!! As u suggested, using an external usb os drive, i can see wifi networks
                  Thanks again!!
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
                  • Flasman90
                    Macbook Pro DFU Restore Issues
                    by Flasman90
                    I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                    - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                    - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                    08-30-2025, 10:27 AM
                  • tobeend
                    Bypass mdm macbook m2 ventura
                    by tobeend
                    1. RESET MACOS WITH IPSW
                    a. Power off MacBook, press and hold the power button to enter Recovery
                    b. Open Disk Utility, remove Macintosh HD
                    c. Reboot, connect to the network to Activate Mac.
                    d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                    d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                    e. Release the other keys, but keep holding the Power key for another 10 seconds
                    f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                    05-26-2023, 07:18 AM
                  • SarcasticOP
                    General question about MacBook power rails for repair.
                    by SarcasticOP
                    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                    • PPBUS_G3H (12.6V-12.8V)
                      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                    • PP3V42_G3H (3.42V)
                      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                    • PPVRTC_G3H (3.3V)
                      • This
                    12-12-2024, 05:50 PM
                  • obelix24
                    A2941 Macbook air 15” - 5V 0a
                    by obelix24
                    I’m working on one macbook air 15” m2 that was water damaged.
                    keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                    i’ve put macbook in shelf and order new screen so i can fully repair it.
                    Now i got the screen and macbook stays at 5v 0a.
                    i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                    i don’t have schematics so i don’t know where to start can someone help me?...
                    03-27-2025, 01:19 PM
