DAX1BDMB6F0 no power
  • pc1staid
    • Apr 2014
    • 55
    • England
    Hi all, I have read through this post https://www.badcaps.net/forum/showthread.php?t=70410 and done some testing myself. Whilst I have been in the repair arena for quite a few years, I have not done much board level repair. It has been more remove and replace. However lately, I have started to do more board level and I am coming unstuck with a few things. People on here and on the Rossmann group forums with know this...
    Anyhow, here is my issue. Got the above mentioned board. No power. Initial issue was a broken DC socket, this has been replaced. Plug in an adapter, no charge light, no power. So, following the thread above and through some of my own testing I have the following results:-
    CN5
    Pin 1&2 19.6v
    Pin 3&4 Gnd
    Pin 5 NC
    Pin 6 1.175v ???
    Pin 7&8 5.042v
    First FET ( i believe is PQ23)
    Pins 5-8 19.6v
    Pin 4 17.69v
    pins 1-3 19.54v ( slight drop but worried)
    Second FET ( I believe is PQ21)
    Pins 5-8 19.53v
    Pin 4 25.28v
    Pins 1-3 19.53v
    From there it seems to fall over.
    At the next FET ( I believe is PQ24)
    Pins 5-8 19.53v
    Pin 4 0v
    Pins 1-3 0v
    I have traced pin 4 of PQ24 to pin 26 on PU3 where again I have 0v.
    Subsequently PQ22 I get
    Pins 5-8 0v
    Pin 4 0v
    Pins 1-3 0v
    As in the post above mentioned, I have tested coils A-G with the following results:-
    A 0.206v
    B 0v
    C 0v
    D 0.000 to 0.001v ( meter i think)
    E 1.025v
    F 5.044v
    G 3.387v
    EC chip:-
    Pin 107 3.255v ( pwr button not pressed) 0.311v ( pwr button pressed)
    pin 119 0v
    I have also found that when i wiggle the pwr btn/ USB/ NIC/ SD Card board ribbon ( the big fat one ( got to love my technical jargon)) I do get the DC skt LED illuminate white and if i connect the battery it goes orange. Press the power button and the board will spring into life. Power off via the button it will restart each and every time. disconnect the adapter and reconnect, fails to illuminate until I wiggle the daughterboard ribbon. Also, if i disconnect the battery and the adapter, the LED with not illuminate and back to no power, yet if I get the LED to illuminate, do not disconnect the battery and disconnect just the adapter, time after time of reconnecting it, the LED will illuminate and the motherboard will power on.
    Any ideas as to the issue. I personally think it is something to do with PQ24 or PU3 as there is no voltage on Pin 4 of PQ24 or Pin 26 of PU3, or this just a red herring. Also, a little concerned as to the voltage drop on pin 6 of CN5. Without the adapter connected the center pin of the adapter reads around the 17v area and I read that when connected to the laptop it should read 17-19v on pin 6 of CN5 but I am getting 1.175v.
    Any help is greatfully received.
    Marc
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: DAX1BDMB6F0 no power
    No need to troubleshoot anything on the board. You simply have a bad contact issue in the DC-in jack.
    The center pin is not making good contact with the socket, hence the symptoms you are observing.
    This is either a bad connector on the AC adapter side, or a bad DC-in jack on the laptop side.
    Replace both with new ones to be sure to fix the problem. AC adapter must be with the same or higher power rating.
    • pc1staid
      • Apr 2014
      • 55
      • England
      @piernov, thanks for the reply. I have replaced the dc socket with one new and one known good, used the original charger and one from a HP omen gaming laptop (130w) with the same result.
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Hi
        It is a gaming laptop which usually have bigger battery 63.3W 6 cell
        You need charger of 150 watt (19.5V,7.6 amps)at least. HP omen laptop original charger is of 150 watts. It matters only for HP computers.
        • corrize
          Where to find a very small fpc connector 0.3mm between 2 pins ?
          by corrize
          Hello, I search this connector (oxydated).
          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
          Do you know how to find this connector please ? What is the exact name for find it ?
          08-06-2024, 05:25 PM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • JaquesPratt
          Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
          by JaquesPratt
          I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
          This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
          07-16-2024, 01:04 AM
        • marce002
          Help me make charger USB C cable with no cc pins!!
          by marce002
          Hi all, please
          I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
          How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
          NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
          here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
          thanks in advance!!
          11-17-2023, 09:16 AM
        • alltvrepairs
          Lg TCon test pins for screen test
          by alltvrepairs
          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
          Appreciate your help....
          06-13-2025, 06:33 AM
