Finding shorts - can a 12v 1a PSU (from a modem etc) be used?
  • seanc
    • Nov 2008
    • 1319
    I've got a couple of laptop motherboards with shorts, but I don't have a bench power supply yet.
    The one I'm working on right now is somewhat disposable.
    It's a Compaq CQ58 (AMD based) (lack of actual schematics) - I can get a brand new board for £19.99 from eBay at the moment and even then it might just all go in the bin.
    So there was a crispy 4435 mosfet (damage seemed mainly on the source and gate side rather than drain) right next to the input for the power DC jack. I pulled another from a dead board - tested OK and installed it. The replacement part starts to get warm rather quickly. There seems to be a lack of protection in the circuit or charger? The output from the charger is about 19v 3a.
    I have a short in the circuit somewhere, evident by quite a few of the surface mount capacitors showing dead shorted (including some on what I believe to be the chipset or GPU). My current method of pulling off each shorted cap from the board and testing to see if the short disappears (or the removed cap is shorted) is tedious to say the least and I'm not particularly skilled at it...
    If I improvised with a modem/hard drive power supply rated at 12v 1-2amps and connected it to the usual 19v input, would this work for helping me to find a short without doing damage (especially to the mosfet which already fried) or would it be the wrong approach?
    Thanks for any advice!
  • piernov
    • Jan 2016
    • 4438
    • France
    Re: Finding shorts - can a 12v 1a PSU (from a modem etc) be used?
    Buy a lab PSU. Or at the very least a DC-to-DC converter with adjustable voltage and constant current mode (DPS3005 at a minimum), if you already have an acceptable AC-to-DC PSU.
    Also low resistance to ground is normal on CPU/GPU/PCH/northbridge/southbridge core rails.
    • dj_ricoh
      • 2073
      • uk
      No.
      If you apply 12v to CPU rail or gpu rail That requires 0.8 and 1 to 1.2v you will instantly explode them. No matter if they are bad or good.
      You need adjustable voltage and apply that amount that is maxim on that rail.
      Dc line 19v , 3v and 5v always, CPU,you, 0.8v 1.2v but if you go over 1v on gpu you kill it. On 1v the GPU needs to get hot.
      Nevertheless you need adjustable psu. You can't use a normal unadjustable psu.
      • seanc
        • Nov 2008
        • 1319
        Thanks for the responses guys.
        I will look to invest in an adjustable lab power supply.
        In my usage of the 12v 1a PSU, I was intending to use it where there is usually 19v 3a, in order to provide less power throughout the board, to perhaps locate the short without cooking things, or at least as quickly.
        Once I get a power supply, I then need to work out where to apply the power at a specific voltage as there isn't a definitive schematic for this board. Hopefully I can work it out from similar boards which use similar components/layout.
        Also need a new soldering station because the button to decrease the temperature on my Duratool (Maplin branded) ZD-916 is broken. It's not the button or the cable, so it looks like it might be the micro controller on the board.
        • Yanleb
          Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
          by Yanleb
          Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
          I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
          D608, good
          D618 RF101L4S, good (See warning 1 below)
          D619 RF101L4S, good (See warning 1 below)
          D865 RF101L4S, shorted (See warning 1 below)
          IC464 Inverter HA MC74HC1G14, shorted...
          03-09-2020, 12:00 AM
        • modtool
          HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
          by modtool
          Hi to all,
          the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
          I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
          I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
          04-01-2025, 08:22 AM
        • BalkanBoy
          Dead Razer Blade 14 2022, shorted CPU?
          by BalkanBoy
          today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
          Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
          I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
          Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
          I removed coil and injected 0.7V, it draw around...
          09-27-2024, 12:44 PM
        • OOF DIO
          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
          by OOF DIO
          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
          (Had 3 problems, now just 1)
          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
          04-19-2025, 05:03 PM
        • barry101
          Apple 820-3662 VCore shorted to ground.
          by barry101
          Hi, Would appreciate some help.
          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
          Get charger light but no fan spin or chime. No liquid damage.
          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
          06-24-2025, 07:34 AM
