ASUS cant power on x453ma rev 2.0
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have a problem with this board it has a led indicator power buton has 3v I have 5v reading on PJ8100 and 3V on pl8801 I dont have any scheamtic but I have a board view but I dont know where to start to troubleshoot first
  • dj_ricoh
    • 2073
    Re: ASUS cant power on x453ma rev 2.0
    Look for coils and see how much voltage you get after start.
    • piernov
      • Jan 2016
      • 4435
      • France
      If you have Repair Guide it often contains a rough power sequence, it helps to know what state the board is in.
      Otherwise indeed check which power rails are there and which ones are missing, check for short to ground on the main power rails, and check the power state signals too (SLP_…#, SUS…, RSMRST#, stuff like that).
      If you have ITE EC programmer, you can randomly try to replace and flash EC.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        I plug the unit to a powersupply , I press the power button ppower supply unit dont get amps only stable at 4 milliamps
        • karlox
          • Dec 2017
          • 128
          • México
          I had a very similar problem, a team did not turn on overnight. The Bios had been corrupted. The solution, 'reprogram it.'
          • karlox
            • Dec 2017
            • 128
            • México
            https://www.badcaps.net/forum/attach...8&d=1446547331
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              sir i tried your bios but nothing happens
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                check LID & RSMRST on kbc present??
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  EC firmware is in the internal ROM of the EC itself that's why I suggested to replace and reprogram it. Could be something else entirely, but that's a "shortcut" you can take.
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    RSMRSThas 3.3v
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      RSMRSThas 3.3v
                      IF you have rsmrst then logically pch should enable slp s3/s4 signals. Check on kbc pins.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        if you have rsmrst then logically pch should enable slp s3/s4 signals. Check on kbc pins.
                        where can i find it sir idont have any scheamtic
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • ShadowAi
                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                          by ShadowAi
                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                          03-15-2024, 10:46 AM
                        • meraklinetx
                          Asus Z97-a power cycle, no boot no cpu voltage
                          by meraklinetx
                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                          05-10-2023, 06:08 AM
