Dell 3542 2 beep error
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    Hi all
    dell 3542 laptop no display power on but 2 beep error. Ram is good. Ddr3_dramrst# signal not coming how to fix this error
    plz help me
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: Dell 3542 2 beep error
    DRAMRST should be 1.3V approx it's upll done by R410 test it both sides
    • Sanjeewait
      • Aug 2016
      • 63
      • Sri Lanka
      Can't find r410 (have a r409, r401,403 but not a r410
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Pics copy for internet.
        • Sanjeewait
          • Aug 2016
          • 63
          • Sri Lanka
          Thanks i's found it. Now 1.3v ok but same error (2 beep) ram is good
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Check all requirements Ram section
            More check this video
            https://www.youtube.com/watch?v=JWju5kNftok
            • Sanjeewait
              • Aug 2016
              • 63
              • Sri Lanka
              Hmmm... All voltage are ok. (vtt, spd, sda, scl, dramrst, o.v ) but 2 beep
              do you have a another idea
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                you are saying you found R410 and now you have 1.3V whereas on the other hand you are saying dramrst 0v. Do you mean you have 1.3V on one side of the resistor and 0V on the other side??I beleive Dram_RST signal is supposed to be from PCH(single die in this case)
                • Sanjeewait
                  • Aug 2016
                  • 63
                  • Sri Lanka
                  i'm R410 resistor replace. before 1.3v come ram 30 pin. but 2 beep.
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    So you replace the R410 but still 2 beeps?
                    • Sanjeewait
                      • Aug 2016
                      • 63
                      • Sri Lanka
                      Yes
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        test the RAM slot Pin 1 126 203 199 75 200 202 voltages ?
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          just in case ....https://www.dell.com/support/article...s-ddr3l-memory
                          • Sanjeewait
                            • Aug 2016
                            • 63
                            • Sri Lanka
                            I have a 4gb ddr3l ram
                            • Sanjeewait
                              • Aug 2016
                              • 63
                              • Sri Lanka
                              Pin 1 = 0.67v, 126 = 0.67v, 203 = 0.67v, 199 =3.39v, 75 =1.36v, 200 = 3.39v
                              202 =3.39v
                              • Techtiger
                                • Oct 2014
                                • 1601
                                • france
                                OK now test VCC CORE, SYS PWROK, PLT RST ,(LPC FRAME, LPC AD you need a oscilloscope) try with the multimeter CLOCK X1801 XTAL 24.Mhz
