A1708 (820-00840) power issue
  • Deluccia
    • Aug 2017
    • 47
    • uk
    Okay so I've had an absolute nightmare with an 820-00840 board.
    Annoying because I'm usually pretty successful/lucky with my component level repairs.
    If anyone can help me I would be so grateful and also would even pay for the gesture.
    This board has had minor liquid damage on the far side corner where C6491 and many other PPBUS-G3H caps are and also liquid damage where the U7000/battery connector is.
    So after ultrasonic cleaning and replacing all damaged looking or incorrectly valued caps/resistors I plugged in and immediately found that U7800 was getting unbareably hot right at around pin 136 (PPBUS-G3H-CPU) I assumed an internal short and replaced, no excessive heat to report.
    Ive been testing at D6905 and have 0.3V at pin 1 (ppbus-g3h) 20V at pin 2 (DCIN) and 20V and pin 3.
    I removed D6905 to test at pads and found:
    Pin 1: 0V
    Pin 2: 5.8V
    Pin 3: 3.8V
    Ive replaced D6905 and found that i just go back to the same voltages as before.
    I have replaced almost all capacitors on the PPBUS-G3H rail as I had 0 resistance to ground when testing.
    I have replaced U7000
    I have replaced U6990
    Have started looking at Q7030 and Q7040 but feel I'm being led astray.
    I am missing TBA-LX1 last I checked.
    Battery connector has no crossed pins or shorts.
    Maybe the G3H CPU short in U7800 has killed the machine?
    I feel like if i can restore PPBUS G3H I will get all rails back and have power.
    Please can anyone shed any light on this?
    Thanks in advance.
    - Joey
    Board-view and schematic attached if needed.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: A1708 (820-00840) power issue
    So you have a short to ground on PPBUS_G3H right now? How much resistance?
    20V on DC-in, 3.3V on PP3V3_G3H are ok on the other hand?
    • Deluccia
      • Aug 2017
      • 47
      • uk
      Thanks for your reply.
      Yes thats correct, positive to ground beeping at 061 on PPBUS_G3H
      DCIN is 20.3V
      PP3V3_G3H is 3.4V.
      I am looking through schematic to see if there is any components that take in PPBUS_G3H and convert it to a computing power rail, sort of like the retinas did with S5_HS_COMPUTING.
      EDIT: Found it, PPBUS_G3H converts to PPBUS_PMIC at R7835.
      PPBUS_PMIC has the same 061 beeping to ground.
      U7800 removed, still 0.1V on PPBUS_G3H
      • piernov
        • Jan 2016
        • 4439
        • France
        Resistance in ohms, not diode mode. 0.061 seems too low anyway, so you may have a partial short to ground somewhere on PPBUS_G3H, or a shorted high-side MOSFET.
        • Deluccia
          • Aug 2017
          • 47
          • uk
          Hi, Yes tested in OHMS not diode.
          Just tested in diode and found 0.061 anyway.
          Sorry didn't specify that previously.
          Any ideas where to start?
          Really pulling my hair out here, I have a donor board so happy to try everything.
          Thanks again for helping me
          • piernov
            • Jan 2016
            • 4439
            • France
            So it is 61.0 ohms in resistance mode?
            That's indeed too low. But finding a partial short to ground like this is not easy.
            First I'd check if any high-side MOSFET connected to PPBUS_G3H is shorted, by checking resistance between PPBUS_G3H and the output of buck converters. So measure resistance between PPBUS_G3H and L8030, L8060, L7960, L7900, L7730, L7690, L7670, L7430, L7370, L7220.
            • Deluccia
              • Aug 2017
              • 47
              • uk
              Correct,
              I'll boot up board-view and check now!
              • Deluccia
                • Aug 2017
                • 47
                • uk
                Okay,
                Interesting..
                L8030: 238
                L8060: 205
                L7960: 0
                L7900: 31
                L7730: 220
                L7690: 369
                L7670: 444
                L7430: 34
                L7370: 40
                L7220: 36
                PPBUS_G3H still 0.3V
                • Deluccia
                  • Aug 2017
                  • 47
                  • uk
                  Okay Q7960
                  Pin 3: 0.3V
                  Pin 4: 0.3V
                  Pin 5: 0V
                  R7969 fuse is good
                  • piernov
                    • Jan 2016
                    • 4439
                    • France
                    Time to remove Q7960 and pray a lot that the CPU isn't fried.
                    • Deluccia
                      • Aug 2017
                      • 47
                      • uk
                      Q7960 removed tested and replaced.
                      Now have PPBUS_G3H at 12.95V!!
                      going to put it in and see whats working
                      • Deluccia
                        • Aug 2017
                        • 47
                        • uk
                        Not working, no fanspin.
                        All_SYS_PWRGD missing.
                        I'm going to pull my own lips off
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          You have to go down the list of power rails and see which ones you have and which ones you are missing.
                          • Deluccia
                            • Aug 2017
                            • 47
                            • uk
                            Yeah I know I'll be back to it tomorrow.
                            These newer models Im not as familiar with to be honest.
                            I have written and printed a check list i go through for the Air and retina boards but I am unsure with the 2017 and newer boards in terms of order to check and from where they derive from.
                            I'll get there In time.
                            Thank you so much for your help.
                            • befaoim
                              • Nov 2017
                              • france
                              I'm facing a power supply issue on a 820-00840 motherboard. It seems that someone was visiting this board before me. U3100 and U3200 are respectively a CD3215B03 and CD3215C00. I know that both chip must be identical. Does someone know what is the correct reference value?
                              Best regards,
                              Fabrice
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                Replacing both chips with C00 should work.
                                • befaoim
                                  • Nov 2017
                                  • france
                                  Hi Piernov,
                                  Thanks for the reply.
                                  I tried to replace both by C00 but I still don't have the 20V at PPDCIN_G3H. I have 5.2V.
                                  I look for I2C communication between U3100/U3200 and the SMC and I can see both I2C acknowledge so I think both circuits seems to work correctly.
                                  I'm confused between B03 and C00 because I read that this board need B03 here: https://boards.rossmanngroup.com/for...not-turning-on
                                  and the inverse here: https://store.rossmanngroup.com/inde...cd3215c00.html
                                  So I'm lost.
                                  Fabrice
                                  • Instafixx
                                    Macbook A2179 820-01958
                                    by Instafixx
                                    Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                    The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                    I checked the Power Sequences below and found this -
                                    Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                    PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                    PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                    05-20-2023, 05:19 AM
                                  • Devin Anderson
                                    A1708 820-00875-A bios
                                    by Devin Anderson
                                    i have a a1708 efi lock and cannot enter dfu.
                                    Model: Macbook Pro Late 2016
                                    Model Number: A1708
                                    Serial Number: C02SQDCEGVC1
                                    Board id# 820-00875-A
                                    EMC2978
                                    i need to unlock efi please...
                                    10-06-2024, 06:34 PM
                                  • dbuergi
                                    MacBook A1708 820-00840-a speaker making strange noises
                                    by dbuergi
                                    i fixed a A1708 which was not working. Not its booting but the left speaker is making buzzing and sizzling noises. I added a short video to show it.
                                    https://www.dropbox.com/scl/fi/ju6v7...=lewlrdkh&dl=0
                                    I already reflowed the audio codec chips but that didn't help. Any ideas what to do?
                                    06-02-2025, 11:20 PM
                                  • ahoonid
                                    A1708 820-00840 No boot - trackpad clicks - 20V 0.55amp
                                    by ahoonid
                                    Hi everyone.
                                    I have MacBook Pro A1708 with a confusing issue.
                                    The laptop doesn't turn on. Strangely, the trackpad clicks and fan spins. Caps lock doesn't turn on and no chime.
                                    Initially, the amp meter didn't turn on at all on one of the usb c ports. On the other port, I got 20V and half an amp tho (no battery connected).
                                    I replaced the bad CD3215 chip and now it works as well. Both ports turn on with same amp readings.
                                    The initial issue however remains.
                                    No boot. No backlight. No chime. No keyboard. Only signs of life are clickable trackpad...
                                    05-10-2025, 04:19 PM
                                  • EpicFix
                                    MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                                    by EpicFix
                                    Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                                    04-08-2025, 09:55 AM
