00163 No Backlight
  • BrickBreaker
    • 52
    00163 No Backlight
    This was sent in with liquid damage. I have 5v on the LCD detection filter, 5v in to the backlight driver, BKLT enable present, continuity along all these backlight traces, the voltage divider for the first transistor isn't being shorted by the driver. If I manually short it, I get 12V on the backlight because driver is still not telling the second transistor to switch power on the coil. I am stumped. LCD is definitely the right year, done NVRAM reset everytime and I see flashing folder with a flashlight. Replaced driver multiple times including at the same time as the mosfets. Using new drivers everytime from the same batch so I tried a donor board no change. I2C lines to the connector are good now, had to replace the connector but diode mode looks good now. TIA!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 00163 No Backlight
    Current sensing resistor R7700 and traces to LED driver? VDDA and VDDP of the LED driver?
    Feedback? I2C on the LED driver ok too?
    • BrickBreaker
      • 52
      R7700 is good, continuity is there to the driver for current sensing. 5V on VDDA and VDDD of the driver. Feedback is good, I2C lines are good. If I manually short R7702 I get 12V on the otherside of Q7706, but it still isn't getting switched/boosted. Driver has everything it needs but isn't doing it's job.
      • piernov
        • Jan 2016
        • 4439
        • France
        Soldering is good for sure?
        • BrickBreaker
          • 52
          Yea just took another long hard look at my soldering. Also confirmed external video is working over thunderbolt.
          • piernov
            • Jan 2016
            • 4439
            • France
            And SMC_LID high?
            • BrickBreaker
              • 52
              Yes. SMC lid 3.4V lid works as intended when I boot up the board in the case with external (thunderbolt) display attached.
              • piernov
                • Jan 2016
                • 4439
                • France
                Tried another display assembly?
                I'm out of ideas. If everything external to the LED driver is ok then it should be the LED driver itself that's causing the issue.
                • howardc64
                  Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                  by howardc64
                  Problem
                  Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                  Model & Board Pics
                  Conflicting Spec
                  Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                  https://www.shopjimmy.com/vizio-gj-2k1...
                  10-10-2024, 01:16 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • triplefour
                  by triplefour
                  09-13-2023, 10:43 PM
                • osrex
                  LED DRIVER KEEPS DYING
                  by osrex
                  Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                  i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                  i have no datasheet at all for the LED lights, all i have is its length.
                  long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                  as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                  05-05-2025, 03:36 PM
                • totof
                  LG 43UF640V backlight good but black screen and no sound
                  by totof
                  Good morning.
                  I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                  I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                  In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                  HVDD : 7,28...
                  04-13-2024, 11:37 PM
