Macbook pro a1286 touchpad and keyboard not working
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need help on this macbook pro A1286 board id: 820-2915-B. the problem is touchpad and keyboard not working, I already tried replaced with good touchpad and keyboard but still same issue.anyone can help me on this to locate what is the problem with this please!thanks in advance
  • Retro-Hipster
    Tinkerer
    • Apr 2019
    • 125
    Re: Macbook pro a1286 touchpad and keyboard not working
    Are you able to plug a keyboard and mouse into a usb port and have it work? If so, do you see your keyboard/keypad listed under About This Mac -> More Info... -> System Report... ? It should be listed under USB .
    “Men always seem to think about their
    past before they die, as though they were
    frantically searching for proof that they
    truly lived.”
    – Jet (Cowboy Bebop) -
    • String2016
      • Nov 2015
      • 2238
      • philippines
      yes if you plugged in the usb wireless keyboard is working, but internal keyboard and touchpad not working, already tried replacing with working internal keyboard and touchpad but still the same issue. anyone can help me on this please
      • String2016
        • Nov 2015
        • 2238
        • philippines
        anyone can help on this please
        • String2016
          • Nov 2015
          • 2238
          • philippines
          anyone?
          • B2L_Repairs
            Macbook A1706 touchpad and keyboard not working. Please help
            by B2L_Repairs
            Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
            10-09-2023, 04:56 AM
          • User555111
            A2338 13" 2022 MacBook Pro M2 820-02773 Touchpad/Keyboard/Display not working
            by User555111
            Currently Im trying to get this A2338 13" 2022 MacBook Pro M2 to function properly, Right now the trackpad and keyboard are not working but the power button and keyboard backlight are working. the Touch Bar shows display but does not respond to touch. I bought it on eBay and it was described as having a bad lcd. When I received it however I found that it was also missing the wifi and bluetooth antenna along with most of the screws hardware. it was also showing picture on the LCD but no backlight, I could also see some lines on the screen indicating the lcd was also somewhat damaged. on top...
            02-05-2024, 08:16 AM
          • Vliegenier04
            Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
            by Vliegenier04
            Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
            I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
            Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
            06-16-2025, 12:03 PM
          • biosdi
            MacBook Pro A1989 trackpad and keyboard not working
            by biosdi
            Hi guys.
            I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
            thanks...
            04-17-2025, 09:42 AM
          • Featurea
            Macbook air 2019 1932 keyboard not working - no password
            by Featurea
            I bought macbook air 2019 1932 after water damage and managed to turn it on, but keyboard is not working. After plugging it in, it is starting automatically, start button not working. Unfortunatelly there is an Apple account with password, seller told me that he don't know the password so I need to erase whole hard disk, which is not so bad, but the problem is I have to go to OS recovery, but I can't without working keyboard. I tried to do this by DELL hub and connected keyboard, but it is connecting too late to react. So I have two questions:
            1. It this normal that...
            11-03-2021, 06:41 AM
