Macbook Air 820-3437 - Fan 100% and Magic Mouse Screen on Boot
  • fred23456
    • Apr 2019
    • 14
    • United Kingdom
    Hi there,
    Working on a water damaged Macbook Air 820-3437.
    The fan ramps up to 100% on boot and stays that way, I believe the sensor causing this is the touchpad palm sensor as all the others read usual values, aside from this one which reads nothing.
    I checked the touchpad flex, it was corroded so I replaced it with no change in behaviour. I then removed and re-soldered the touchpad connector on the logic board (also corroded inside). This also did not fix the problem. I swapped the touchpad for a replacement and still have the issue. I've tried the unplug the webcam cable trick to see if it's a sensor on that line and that does nothing too.
    The computer now boots into the "Trouble entering your password screen" as if to suggest the keyboard isn't connected.
    Really racking my brain with this one and worried it may be an SMC problem?
    Any help would be much appreciated!
  • fred23456
    • Apr 2019
    • 14
    • United Kingdom
    Re: Macbook Air 820-3437 - Fan 100% and Magic Mouse Screen on Boot
    Just an update to this, the mac now boots into the OS. I blew a little air into the keyboard/touchpad connector on the logic board and must've cleared out something. The keyboard and touchpad are working properly now.
    The fan is still spinning at 100% and the computer is running a bit slower than usual.
    • piernov
      • Jan 2016
      • 4435
      • France
      Run ASD to find out which sensor is causing the issue.
      • fred23456
        • Apr 2019
        • 14
        • United Kingdom
        Hi there, sorry for the delay in responding. Managed to find and setup ASD.
        Failed tests are as follows:
        Ts0P Trackpad Skin - reading below the low limit.
        Last edited by fred23456; 05-26-2019, 02:20 PM. Reason: Re-tested with battery connected, different results.
        • piernov
          • Jan 2016
          • 4435
          • France
          Yeah so it's indeed related to touchpad. Either bad touchpad, bad cable or and issue with the connector on the logic board still. I think the sensor readings go through the SMBUS (pin 16/17) so you may want to pay extra attention to those lines.
          • fred23456
            • Apr 2019
            • 14
            • United Kingdom
            As mentioned previously, I've switched around 2 touchpads, tried 2 new flexes and have soldered 2 new connectors onto the board and the issue remains the same whilst other problems with the keyboard/touchpad disappeared.
            As far as I can tell from the schematic the data line from the touchpad connector goes straight to the SMC on this board? Would really appreciate if you could verify whether I'm right or not.
            • piernov
              • Jan 2016
              • 4435
              • France
              U5810 is on the same SMBUS than the touchpad, so if there was an issue with the SMC or the bus itself I'd expect you to have more than one sensor issue (assuming you did "continue on error" in ASD).
              The SMBUS connection is indeed direct between touchpad connector and SMC (and U5810).
              You could check if you have continuity between the touchpad connector and U5810 for the SMBUS lines just to make sure there's no break in the SMBUS lines near the touchpad connector.
              • fred23456
                • Apr 2019
                • 14
                • United Kingdom
                I did indeed continue on error in ASD. The touchpad is definitely the only sensor that's wrong.
                I have 3.3 volts on SMBUS at U5810 on pins 9 and 10 and on R5390 and R5391. Pin 16 (SMBUS_SMC_3_SDA) of the connector is also 3.3V but pin 17 (SMBUS_SMC_3_SCL) is 0.4V
                I can't get continuity on SCL to U5810. Easily get it resting the probe on U5810 pin 9 and running it across the connector but nothing on pin 10. Is it time to start running jumper wires?
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Yeah if SCL is not good on the connector but is good at U5810, there's a break in the line somewhere. Check under microscope if the pin is not soldered or the pad is gone, and see if you can find a via to solder to. Otherwise you'll have to run a jumper wire across the board to the other side.
                  • fred23456
                    • Apr 2019
                    • 14
                    • United Kingdom
                    Ran the jumper loosely round the board to test and the fan spin is back to normal! Going to get some solder mask to make sure it's insulated and doesn't cause any other issues. It's a bit of a journey it has to take round the board! I'll give ASD another run and check whether the sensor passes once I've got the wire routed properly.
                    Cannot thank you enough for your help! You've helped save my computer from what I thought was certain death.
                    -EDIT-
                    Tested with ASD after routing the jumper properly. Ts0P reading properly. Boots to the OS, everything working as it should. Thanks again Piernov!
                    • No Lan
                      [Macbook pro A1708] [Boot loop] [Trackpad ?]
                      by No Lan
                      Hey everyone,
                      Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                      Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                      Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                      05-24-2025, 03:09 PM
                    • twonk9098
                      Macbook Pro mid 2015 battery required to boot?
                      by twonk9098
                      I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                      The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                      This model has the newer trackpad which is not clickable when turned off.
                      At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                      If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                      12-10-2024, 06:51 PM
                    • veedo
                      Macbook A2442 820-02098 boot and display issue
                      by veedo
                      Hi All
                      I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                      Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                      I found component UD290 ( SF0101-I2C) little...
                      04-01-2024, 06:06 AM
                    • PITERPENY
                      Macbook A2251 no boot
                      by PITERPENY
                      The MacBook does not boot. It is restored via DFU without errors. The MacBook charges and consumes 20V/2A. There is no sound when connecting the charger. The caps lock does not light up, but the touchpad clicks. The fans do not rotate. No signs of life. Please advise.
                      01-05-2025, 03:11 PM
                    • baglaivlad
                      MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
                      by baglaivlad
                      Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
                      Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
                      01-09-2024, 09:55 PM
