Hp 6730s (605A2161001-MB-A02) no power no charge
  • eniac22
    • 124
    • Greece
    Hp 6730s (605A2161001-MB-A02) no power no charge, its working ok with battery only, i have 19.70V on Q1032 pin 1,2,3,4 & 0V on pin 5,6,7,8.
    I have make a trick i break connection of pin 4 (Gate, Q1032) and now its working.
    On pin 3 of the dc port (Limit_Signal) i get 0V
    The problem is with the Limit_Signal, how can repair this?
    Schematic moved to new thread - https://www.badcaps.net/forum/showthread.php?t=124724
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Hp 6730s (605A2161001-MB-A02) no power no charge
    Are you using the original 90W adapter, Voltage on U1021 all pin except GND, voltage in R 53 both sides
    • eniac22
      • 124
      • Greece
      First i want to tell you a big THANK YOU because you always try to help me.
      The adapter is the original and and is mark as 18.5V but its output 19.5V, i have try and universal adapter.
      With the Q1032 soldered correcly (no break on pin4, no battery connected) i have 0V on U1021 & R53.
      With pin 4 of Q1032 not connected (system off,no battery connected) i have the follow voltage
      R53 = 0V (both sides)
      U1021:
      pin 1 = 2.25V
      pin 3 = 0V
      pin 4 & 5 = 4.97V
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Very complicated mob there are a lot of +3VAL & +5VAL , Test your charger middle pin outside of the mob, may be LM393 is faulty May be test R1338
        • eniac22
          • 124
          • Greece
          The middle pin on universal charger is 3V & on original is 0V, how many volts must be the middle pin? Because i have 0V on the pin 3 (midle pin) of DC Port i will try to change the dc port
          • Techtiger
            • Oct 2014
            • 1602
            • france
            HP power adaptor middle pin has around 10-19V while Dell has up to 5-6V onewire (digital ID) communication
            • piernov
              • Jan 2016
              • 4435
              • France
              Out of circuit HP adapter will appear to have 19V on center pin. When connected to the board, the AD_ID pin (center pin) will be between 0 and 3V. It works as a voltage divider, upper resistor in the power brick between 19V and center pin, lower resistor on the motherboard between center pin and ground.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                thanks Piernov
                • eniac22
                  • 124
                  • Greece
                  Problem solved, thanks all for your help
                  • ipatch
                    troubleshooting microsoft surface pro 4 no power no led charge light
                    by ipatch
                    hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                    10-05-2023, 11:59 AM
                  • ruletero
                    Acer a515-43 low battery charge voltage
                    by ruletero
                    Hi
                    Acer A515-43
                    LA-H801P
                    Fail: Does not charge battery, has low voltaje on connector.
                    Laptop didn't want to turn on, only charge led blinked.
                    I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                    I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                    Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                    10-24-2022, 02:31 PM
                  • Klevjetack
                    Charge a L19D3PDA battery externally from the laptop
                    by Klevjetack
                    Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                    03-05-2024, 07:26 AM
                  • razenxd
                    How can I charge that battery pack?
                    by razenxd
                    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                    Now, I have noticed a few things.
                    The "dead" battery, while connected to charger and NOT Charging will...
                    12-05-2024, 06:11 AM
                  • Elektronror
                    Asus GL702VS No charge, unstable GPU power
                    by Elektronror
                    First post here, second if you count the introduction thread, so don't hesitate to tell me if I'm doing something wrong.
                    Bought a used Asus GL702VS which had been sitting for a while so it arrived with a dead battery. Plugging in the charger it came back to life and I didn't notice any problems with the computer. I also used it running on battery for 1-2 hours. I then played around with undervolting the CPU with the charger connected when a 10uF MLCC shorted AC_BAT_SYS. After removing the short, battery won't charge and the GPU has power limitations. I suspect that these are 2 different...
                    02-05-2021, 10:39 AM
