ASUS X555LD - no voltage after first mosfet
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    hello.
    Have this ASUS X555LD, that have no voltage/0.88V/ after first mosfet. on gate of it is same little voltage
    my measurements give nothing for me and jumping fist two mosfets bring it to life, so there must be problem in this charging side
    replaced that BQ24735 with known working one, but readings are the same
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Re: ASUS X555LD - no voltage after first mosfet
    sorry for bothering u guys.
    the second mosfet was faulty. after replacement everything works
    • piernov
      • Jan 2016
      • 4435
      • France
      Yep common fault on Asus boards. Still not sure what causes that.
      • phonesafept
        • Mar 2023
        • 3
        • Portugal
        Thank you, solved mine right now with your reply|
        • nevenne
          • Jan 2024
          • serbia
          Do you have shorts after mosfets
          • alro7779
            MOSFET? Is its voltage reading normal?
            by alro7779
            Hello, guys!
            Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
            06-19-2025, 08:19 AM
          • Scotchmist
            Asus GA502D keeps blowing mosfet
            by Scotchmist
            I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
            I have removed the mosfet and can run the laptop no problem
            The MOSFET is FDPC5018SG
            Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
            08-24-2024, 02:23 PM
          • MicroSMD Lab
            ASUS ROG Zephyrus GPU Mosfet repeat failure
            by MicroSMD Lab
            The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
            I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
            01-10-2024, 06:36 AM
          • Chewy6288
            Asus FA506QE missing MOSFET
            by Chewy6288
            I recently bought this laptop to try to fix up because it was so cheap. It has no power so I figured it was a MOSFET or cap issue so I started with taking it apart, but when I had it apart I noticed one of the MOSFETs was missing. I'm new to this so I don't know where or how to look up what to replace it with. I do have the boardview for it so I somewhat know what was there which I attached ,and the missing piece is PQ303....
            Today, 07:24 AM
          • Timp74
            Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
            by Timp74
            Hi All,
            Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
            I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
            08-13-2021, 01:11 PM
