Dell Latitude E6430 doesn't recognize adapters
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell Latitude E6430 doesn't recognize adapters
    I'll suggest to replace pq2/pq3.
    • Iherduleikgemz
      Dell Vostro 15 3568 15341-1 91N85 - Won't recognize battery and charger
      by Iherduleikgemz
      Hello everyone
      I have been working on this laptop mentioned in the title, it initially had a blown PQ4410 mosfet. After I replaced it and repaired the damaged PCB the thing started working again, but there is still another problem. The laptop won't recognize genuine battery and charger. I have 3.3v KBC PIN36 PS_ID and this is pretty much where my knowledge ends.
      Where should I go next? Replace the KBC or measure something else?...
      Yesterday, 09:56 AM
    • judamex
      Dell Alienware M15 R7 (intel) LA-L651P does not recognize Nvidia RTX 3060M dGPU
      by judamex
      Hello, I have a Dell Alienware M15 R7 INTEL LA-L651P which does not detect the dGPU which is a 3060M, I tried reprogramming both BIOS, without success, the dGPU has all the voltages, I do not know how to make it turn on properly with an external power supply, since outside the case, it only turns on for a second and turns off.
      I tested in vBios and on pin 2 of the eeprom I have no voltage, on pin 1 I do have 1.8V
      I also disabled the hybrid GPU in the BIOS settings and the Windows startup sound is heard but there is no image, with a color code of 2 red and 7 blue on the power LED. It...
      06-08-2025, 12:12 AM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
    • OntarioTL
      Dell 5410 greyed out BT
      by OntarioTL
      Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
      If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
      Dell Lattitude 5410
      Service Tag...
      Today, 01:28 PM
