Good day great engineers. I have this system hp 1040 g1 whenever it is shutdown say one hour or above and is about to be used again the battery would have drain to the point that it would not come on unless plug to Light yet the battery is OK if u charge it will last up to two hours b4 it runs down. So why dose it drain when shutdown and how can I solve the problem please?
Hp folio 1040 g1 draining battery
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by mkdjHello everyone,
Mark and model: ASUS X571
Tests already made:
- I have removed... -
NVDC charger configuration...-
Channel: Common Parts Library - Datasheets
11-05-2024, 03:28 PM -
by ferah831208Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
- Loading...
