Macbook pro A1278 no picture on the screen
  • String2016
    • Nov 2015
    • 2238
    • philippines
    This is the first time to repair mac book, I need help on this to guide me to repair this please. This is MAC BOOK PRO A1278 EMC2554, the problem is pressing power button i heard the chime sounds and there is light on the screen but no picture, i tested both screen and flex to another mac screen is ok.can anyone help me guide to repair this please thanks in advance
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Macbook pro A1278 no picture on the screen
    test lcd power. i think u r missing 3.3v power for it. check schematic
    • String2016
      • Nov 2015
      • 2238
      • philippines
      thanks for the response, could you guide me where to check please
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        on lvds connector
        • String2016
          • Nov 2015
          • 2238
          • philippines
          thanks i check on lvds connector PP3V3_LCDVDD on pin2 and pin 3 no voltage. where to check next please
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            look at the schematic where it comes from, i supose there is switching mosfet
            • String2016
              • Nov 2015
              • 2238
              • philippines
              does the mosfet connected is the U9000?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3627
                • slovakia
                dont know there are lot of A1278 boards.
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  anyone can help me on this please
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3627
                    • slovakia
                    post right schematic or board marking
                      • 21916
                      Have you tried a PRAM and SMC reset .
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        the board has marking 820-3115-B
                        • String2016
                          • Nov 2015
                          • 2238
                          • philippines
                          @SMDFLEA i did not tried PRAM AND SMC RESET. this mac working on external display
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3627
                            • slovakia
                            u9000 is actually that switch. check its input and output, ON signal
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              thanks ktmmotocross the problem is i cannot find the U9000 on the board located
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3627
                                • slovakia
                                https://www.badcaps.net/forum/attach...3&d=1468078887
                                • String2016
                                  • Nov 2015
                                  • 2238
                                  • philippines
                                  file has a password and how to open this file
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3627
                                    • slovakia
                                    https://www.badcaps.net/forum/attach...1&d=1481251744
                                    • piernov
                                      • Jan 2016
                                      • 4439
                                      • France
                                      Screen needs to be recognized in order to get power on pin 2/3. It gets recognized from the DDC bus, on pins 6 and 7. DDC is powered on pin 4.
                                      Basically, you need 3.3V on pin 4 before anything.
                                      You need the LCD to be plugged in to measure voltage on the connector.
                                      Check for liquid around LCD connector and make sure it's not damaged.
                                      • String2016
                                        • Nov 2015
                                        • 2238
                                        • philippines
                                        i measured the voltage with lcd plugged in
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • MagJ_
                                          MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
                                          by MagJ_
                                          Hello Everybody,
                                          I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
                                          10-09-2024, 02:51 PM
                                        • sofles
                                          Macbook Pro 16" A2141 screen artefacts, kernel panic
                                          by sofles
                                          Hi there.
                                          I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
                                          I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
                                          Now situation looks like this, If...
                                          02-05-2025, 05:05 AM
