Lenovo SL400 Dead. Need Help
  • Jesse James
    • Sep 2018
    • 95
    I have a Lenovo Rocky 40-50 board that battery light comes on and charges but thats it. I know its old but in mint shape. I have traced power sequence and found SIO is seeing the following
    power button
    SUS_PWRGD
    RSMRST
    My 3.3v and 5v are present but what i did notice was no
    SYSTEM_PWRGD at SIO
    no PM_PWRBTN out of SIO
    no +3vs on pin 11 going to SIO
    I get confused if 3vs is always present or not.
    I have attached schematics i am working with.
    Any help would be appreciated
    Thank You
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Lenovo SL400 Dead. Need Help
    test TPS51120 pin 19 & 21 , you need +3VA for SIO BIOS ect ,+3VS comes after PWRBTN ,do you have 3.3V on RSMRST ?
    • khaahk
      • Dec 2013
      • 786
      • Estonia
      PWRSW# comes to sio?
      LID_SW# is high?
      How much current is drawn from adapter?
      Does sio get warm? (if current drawn is higher than 30mA)
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Test U8101 pin 5 +12VSUS , SIO pin 14 EC RST
        • Jesse James
          • Sep 2018
          • 95
          Thanks for the quick info. Here is what i have
          Bios pin 8=3.3v
          EC RST= 2.82V
          U8101 pin 5=12v
          Lid_SW# =3.3V
          RSMRST=3.3v
          PWRSW# =3.3V and goes to 0v on sio when pressed
          TPS51120 pin19=3.3v
          pin21=5v
          Current draw with psu is 10mA
          It goes to 15-20mA when power button pressed
          Nothing on the board warms up
          Does this look like a dead sio
          • Techtiger
            • Oct 2014
            • 1602
            • france
            Does it have activity on BIOS CS# pin?
            Any activity on pin 121 & 25 SIO PM SUSB PM_SUSC
            Check pin 3 & 7 , try and flach Bios save the OLD Dump first
            • Jesse James
              • Sep 2018
              • 95
              No activity on CS# 3.3v
              sio pin 121 & 25 no activity
              No activity on any pins but all i have is volt meter
              I flashed the bios with one found online and still no change (saved old dump)
              • khaahk
                • Dec 2013
                • 786
                • Estonia
                what do you mean by:
                • Jesse James
                  • Sep 2018
                  • 95
                  I assume PM_PWRBTN is the output from sio to ICH but not sure
                  It has 3.3v but no change when pressing power button
                  My input from power button to sio goes to 0 when pressed
                  • khaahk
                    • Dec 2013
                    • 786
                    • Estonia
                    It should go up to 3V after pressing powerbtn and then low for a moment but you can not see it with multimeter. ICH should respond with susb and susc going high, if i am correct. Does it happen?
                    • on/off
                      • Oct 2016
                      • 333
                      • Indonesia
                      RTCRST# and SRTCRST# signal?
                      • Jesse James
                        • Sep 2018
                        • 95
                        Sorry wrote that wrong and too late to edit
                        PM_PWRBTN 0v and does not change
                        susb and susc 0.23v and does not change
                        I have not been able to trace RTCRST# and SRTCRST# as this board does not have any reference other than JP and H.
                        • khaahk
                          • Dec 2013
                          • 786
                          • Estonia
                          Looks like it.
                          • Jesse James
                            • Sep 2018
                            • 95
                            I found a boardview that is similar and have been able to test further. It looks to me like a faulty TPS51120 chip. Does anyone know if there is a chip equivalent to this as I have some used boards to use.
                            • Nagyesz
                              Lenovo ideapad 330ICH - Dead, no volts on coils
                              by Nagyesz
                              Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                              I've never encountered something like this before;
                              No charging light, full dead
                              Lenovo Ideapad 330-17ICH
                              • PL3102: 5 ohms
                              • PL3001: 3.2 ohms
                              • PL3101: 2 ohms
                              • PL5801: 3.5 ohms
                              • PL5501: 270 ohms
                              • PL701: 35 ohms
                              • PL501: 146 ohms
                              • PL503: 390 ohms
                              • PL402: OL (0.27V) +5VALW_P
                              • PL301: OL
                              • PL401: OL (0.03V) +3VALW_P
                              + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                              10-11-2024, 10:12 AM
                            • Zmay2509
                              Lenovo T14 nm-c931 1th gen intel 10th DEAD
                              by Zmay2509
                              Hi, I have dead t14 gen1 with nm-c931 motherboard.
                              Laptop doesn't turn on and does not show any sings of life.(battery is completely flat, do I need it for power on??)
                              When I connect usb c power adapter it draws 0.02A at 20v, I get voltage 20.5V up to 2nd mosfet and nothing out (PQ0006 before current resistor and buck-boost) when I touch gate pin of PQ0006 with tweezers it opens and I get 20.5v on current resistor;
                              But even with that "trick" I cant get laptop to turn on, that's probably because BQ25700ARSNR is not happy and not making VSYS15 rail.
                              03-25-2025, 02:44 PM
                            • madan1
                              Lenovo Ideapad S130 is the CPU dead?
                              by madan1
                              Good day.
                              I'm trying to figure out what's wrong with a Lenovo Ideapad S130 motherboard. When I connect it to the bench PSU and limit the supply to ~2.2A (about the limit of the lenovo stock PSU), the board absorbs all the amperage and the voltage on the PSU drops down to about 4-5V.
                              The components on the board that get hot are the two mosfets ( 1 and 2 on the photo ) and the CPU. The resistance to ground measured on the power rail coils can be seen on the image (~17 and ~50 ohms). On the top of the CPU there are few caps which measure dead short. I checked all caps on the top side...
                              03-14-2024, 09:14 AM
                            • reformatt
                              Lenovo NM-A921 (Yoga 900-13ISK2) dead
                              by reformatt
                              This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
                              So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
                              Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
                              02-05-2025, 05:24 PM
                            • angel-boy
                              Lenovo M70Q - 11E8 - that is dead
                              by angel-boy
                              hy, i have a PC M70Q - 11E8, that is dead, no power led, no logo led , change the CPU, still dead !
                              - pc is like new but with OS amazon.Gringotts2, i try to program bios 16mb, nothing, i change the 16mb W25Q128 with other, write another dump file, still no power up, replace again W25Q128 with other and write another dump file, still DEAD
                              - i have 3v3, 5v, 1v and others voltage. power botton drops to 0 and back 3v3.
                              my question , is possbile this pc will not power up becouse is locked ? maybe need a lan wake up , i dont know.​
                              03-29-2024, 07:21 AM
