Lenovo T14 nm-c931 1th gen intel 10th DEAD
  • Zmay2509
    • Feb 2025
    • 5
    • Croatia
    Hi, I have dead t14 gen1 with nm-c931 motherboard.
    Laptop doesn't turn on and does not show any sings of life.(battery is completely flat, do I need it for power on??)
    When I connect usb c power adapter it draws 0.02A at 20v, I get voltage 20.5V up to 2nd mosfet and nothing out (PQ0006 before current resistor and buck-boost) when I touch gate pin of PQ0006 with tweezers it opens and I get 20.5v on current resistor;
    But even with that "trick" I cant get laptop to turn on, that's probably because BQ25700ARSNR is not happy and not making VSYS15 rail.
    from groung to VINT20_IN (after PQ0006 mosfet) I have 31Mohm, between ground and inductor coil I have 45Kohm, and between ground and VSYS15 I have around 1Mohm.
    I don't have experience with Lenovo boards and BQ chips so any idea is appreciated (I have thermal camera, DC power supply and oscilloscope if additional measurements are needed)
  • rumpumpel1
    • Jul 2019
    • 165
    • germany
    You don't need a battery to turn it on. A bare board with just a fan should turn on the moment you plug in a charger.
    Is the behavior the same for both USB-C connectors?
    What happens if you try to power up the board with just a (charged) battery?​
    • Zmay2509
      • Feb 2025
      • 5
      • Croatia
      Hi, thanks for reply.
      When I connect charger to second usb-c port I don't get any voltage.
      I don't have charged battery to try :/
      • rumpumpel1
        • Jul 2019
        • 165
        • germany
        testing with a charged battery is important, because you know if the fault is either before (and including) the battery charger or after the battery charger.
        • pc_okay
          • May 2022
          • 244
          • FRANCE
          Hello friend,
          please mesure voltage on pin 4 Of pq05
          and Check both mofset 05 & 06 résistance both side
          gare <> source
          gâte <> drain
          drain <> source
          Check solder too on both mofset last Time, one mofset was partialy desolder, I think on a similar model.
          • Ublala Pung
            Lenovo V15 and V17-IIL and probably others with 10th or 11th gen CPU suffer from a design flaw
            by Ublala Pung
            The Lenovo laptops V15 and V17-IIL with I5 or i7 CPU and probably many other Lenovo laptop from this time with 10th or 11th generation Intel CPU suffer from a design flaw regarding the display/camera/microphone connector on the motherboard which is badly placed and the cheapest of the cheap connectors imaginable. As the cable is too near to the display and the connector does not fix it proper in place the cable develops little defects and those over time lead to a plethora of possible quirks or failures starting from the named RAM problem or sudden switching off in special when the display is...
            04-23-2025, 04:47 PM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
          • Nagyesz
            Lenovo ideapad 330ICH - Dead, no volts on coils
            by Nagyesz
            Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
            I've never encountered something like this before;
            No charging light, full dead
            Lenovo Ideapad 330-17ICH
            • PL3102: 5 ohms
            • PL3001: 3.2 ohms
            • PL3101: 2 ohms
            • PL5801: 3.5 ohms
            • PL5501: 270 ohms
            • PL701: 35 ohms
            • PL501: 146 ohms
            • PL503: 390 ohms
            • PL402: OL (0.27V) +5VALW_P
            • PL301: OL
            • PL401: OL (0.03V) +3VALW_P
            + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
            10-11-2024, 10:12 AM
          • reformatt
            Lenovo NM-A921 (Yoga 900-13ISK2) dead
            by reformatt
            This machine has been in a few times with an intermittent fault of not charging. Motherboard is NM-A921 (https://www.badcaps.net/filedata/fetch?id=2051581)
            So back again now, not working at all. Previously the adaptor had been replaced along with the DC charge port. This is one of these trapezoid shaped orange USB ports that Lenovo were using prior to going USB-C. It has 4 pins, but the DC connector jack on the PCB has 5 pins.
            Fault presentation was the adaptor is only producing 5.2V, not 20V and this isn't reaching the input of the NVDC charger (PQ5/PQ6). There are 5...
            02-05-2025, 05:24 PM
          • madan1
            Lenovo Ideapad S130 is the CPU dead?
            by madan1
            Good day.
            I'm trying to figure out what's wrong with a Lenovo Ideapad S130 motherboard. When I connect it to the bench PSU and limit the supply to ~2.2A (about the limit of the lenovo stock PSU), the board absorbs all the amperage and the voltage on the PSU drops down to about 4-5V.
            The components on the board that get hot are the two mosfets ( 1 and 2 on the photo ) and the CPU. The resistance to ground measured on the power rail coils can be seen on the image (~17 and ~50 ohms). On the top of the CPU there are few caps which measure dead short. I checked all caps on the top side...
            03-14-2024, 09:14 AM
