Asus GL503V mosfet identification
  • wwbielsko
    • Aug 2008
    • 59
    Please identify for me what type (model) of mosfet is used at the place which is signed on photo.
    Motherboard model: DABKLAMB8D0 REV D
    dc/dc converter battery charger is BQ 24780s
    best regards
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Asus GL503V mosfet identification
    the marking code on the mosfet is not readable in this photo. you should read it under a microscope and mention the code here.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3588
      • slovakia
      that mosfet is easy findable. just put 4digit number on him to google with word MOSFET after numbers.
      u can replace it with any same packet mosfet with same channel and nearly or more amperage
      • wwbielsko
        • Aug 2008
        • 59
        thanks for reply, but im not into about reading model from soldered one but to find the exact model which is provided with motherboard
        i have got battery charging problem while I had replaced the mosfet with new one N channel 30V prewious was shorten and problem still exists, i thrown away old one so I need to find the mosfet model
        its not about reading from soldered
        orginal one and replaced could have little difrences so it could not solve the battery charing problem
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3588
          • slovakia
          no little differecies matter. only what matters is channel and amperage. if have still problem u must search elsewhere.
            • 20795
            Rework those 2 caps. Put some kapton tape or foil on the 2 connectors above so they do`nt get melted any further,if you rework using hot air .
            • wwbielsko
              • Aug 2008
              • 59
              Dont worry, they will be done ok cause I've take them out to find shortage.
              Doeas any 1 know what mosfet is there ?
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3588
                • slovakia
                did u try to use that switch behind battery connector? as i see it is not lid switch but intrusion detection switch
                • wwbielsko
                  • Aug 2008
                  • 59
                  its not about switch, because voltage state is flowing around this mosfet and sth is not ok so im looking for mosfet exact model, im sure i solder in correct one according to n type and voltage but maybe other characteristics are little bit different
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3588
                    • slovakia
                    so u think if it is 19V on input of that mosfet than mosfet must be bad?
                    mosfet is just fast switch. the main things is going inside of driver of that mosfet
                    • Nuvoton
                      • Jun 2017
                      • peru
                      codigo mosfet AON6435...
                      • Revilo1807
                        • Sep 2021
                        • Guatemala
                        I need board view
                        • guizmo1967
                          Asus VG278 mosfet identification ?
                          by guizmo1967
                          My Asus monitor stop working today !! I found the problem on the main board, the power supply board is ok. It's Q9, a mosfet but I have no idea what are the specs since I don't have the schematic for that monitor !!
                          Can someone help me identified this mosfet ?
                          Thank you !
                          04-16-2024, 01:15 PM
                        • AppleLover123
                          Asus X712EA 3 volts after the first mosfet
                          by AppleLover123
                          Hey guys,
                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                          Now i thought something...
                          12-15-2024, 07:49 AM
                        • Scotchmist
                          Asus GA502D keeps blowing mosfet
                          by Scotchmist
                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                          I have removed the mosfet and can run the laptop no problem
                          The MOSFET is FDPC5018SG
                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                          08-24-2024, 02:23 PM
                        • MicroSMD Lab
                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                          by MicroSMD Lab
                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                          01-10-2024, 06:36 AM
                        • Timp74
                          Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                          by Timp74
                          Hi All,
                          Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                          I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                          08-13-2021, 01:11 PM
