Toshiba c840 not charging battery when power on
  • String2016
    • Nov 2015
    • 2230
    • philippines
    I need help on this please. i have here a Toshiba Satellite C840 laptop with BOARD IDABY3CMB8E0 REV:E.Everything works fine when charger only plugged in and with battery plugged in only, but the problem is you can charged the battery only with no issue with the laptop is off, but when it is power on and you plugged the charger it cannot charge the battery as one component is heat up. i have upload a image on the component on the board.please help
  • smali
    • Sep 2014
    • 287
    • Pakistan
    Re: Toshiba c840 not charging battery when power on
    check PQ5001 and PQ5002 may be short ?
    • String2016
      • Nov 2015
      • 2230
      • philippines
      I check pq5001 and pq5002 mosfet there is no short and not beeping on the multimeter.
      • String2016
        • Nov 2015
        • 2230
        • philippines
        anyone can help on this please already tried removing PQ5001 AND PQ5002 mosfet and test it but no short
        • String2016
          • Nov 2015
          • 2230
          • philippines
          anyone can help me on this please
          • Techtiger
            • Oct 2014
            • 1601
            • france
            Try to mesure The battery Coil for Ohms and the +- pins of battery connector Ohms to GND try to upload the Schematic
              • 20732
              Replace pd1 and the caps with corrosion .
              https://cdn.badcaps-static.com/pdfs/...c3b4384ec2.pdf
              • piernov
                • Jan 2016
                • 4435
                • France
                It's normal for the diode to heat up a bit under high load, 0.5V voltage drop across the diode with 4A is 2W, so yes it'll make it heat up a bit. I see flux around there so make sure the diode is the proper one. Also if the battery is not charging while the computer is being used, maybe the battery is bad or the AC adapter is not the proper rating.
                  • 20732
                  PQ5003 looks like it needs rework as well .
                  • String2016
                    • Nov 2015
                    • 2230
                    • philippines
                    @techtiger battery coil in ohms mode red probe to ground and black to both sides of greycoil mesured 0.255 both coils
                    • String2016
                      • Nov 2015
                      • 2230
                      • philippines
                      @smdflea should i replaced PD1?this is heats up if i plugged the charger with the laptop is on but when laptop is shuts off it charge good
                      • String2016
                        • Nov 2015
                        • 2230
                        • philippines
                        @piernov both charger and battery are good
                        • String2016
                          • Nov 2015
                          • 2230
                          • philippines
                          the only problem with this board is not charging when laptop is on when i plugged a bench lab with battery plugged in taking amps and PD1 heats up.but when laptop shuts off and plugged the charger and battery and turn on its working fine and charge the battery without issue
                          • String2016
                            • Nov 2015
                            • 2230
                            • philippines
                            • String2016
                              • Nov 2015
                              • 2230
                              • philippines
                              no one can help on this please
                              • String2016
                                • Nov 2015
                                • 2230
                                • philippines
                                Problem solved on this it was PC22 is the culprit replaced it and now its working fine
                                • Techtiger
                                  • Oct 2014
                                  • 1601
                                  • france
                                  can you uplode the schematic, Great you solved it
                                    • 20732
                                    Schematic at post #7
                                    • Techtiger
                                      • Oct 2014
                                      • 1601
                                      • france
                                      Thanks SMDFlea
                                      • String2016
                                        • Nov 2015
                                        • 2230
                                        • philippines
                                        now i have new problem with this laptop display becomes WHITE screen, already done replaced with new lvds cable still the same issue, replaced with new screen same issue, i have check on the schematic the LCDVCC is missing on pin23 on lvds connector, and on U26 chip here is the voltages
                                        PIN1= 0V
                                        PIN2= 0V
                                        PIN3= 3.3V
                                        PIN4= 3.3V
                                        PIN5= 0V
                                        PIN6= 3.3V
                                        Noticed that the out the PIN1 Is the output of the chip because pin 2 and pin 5 is ground.does anyone help me on this to solved this problem please
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Julian Bailey
                                          HP ProBook 445 G8 Battery not charging
                                          by Julian Bailey
                                          Hi all
                                          We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                          The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                          I have gone around the board with a MM and cant find anything
                                          Windows shows the battery fine,...
                                          10-11-2024, 10:34 AM
                                        • piernov
                                          Laptop battery charging circuit
                                          by piernov
                                          1. Some theory
                                          1.1. Introduction
                                          Almost every laptop has a charging circuit of some sort, that does a few things:
                                          • Manages switching between AC adapter and battery power
                                          • Manages battery charging and generates power rail to charge battery
                                          There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                          • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                          • Narrow VDC (NVDC)
                                          Texas instrument has a nice overview of these technologies with some more details at https:...
                                          11-15-2020, 01:31 PM
                                        • kodox
                                          ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                                          by kodox
                                          since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                                          the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                                          what i've done:
                                          - flashing...
                                          12-29-2024, 02:49 AM
                                        • Shinju
                                          Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                          by Shinju
                                          Hey All!
                                          Long time forum member here with a problematic laptop issue!
                                          I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                          The laptop would not power on with the new battery installed without the power supply being plugged in.
                                          When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                          TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                          10-20-2021, 04:58 PM
