Toshiba c840 not charging battery when power on
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Toshiba c840 not charging battery when power on
    Originally posted by Mulong2019
    now i have new problem with this laptop display becomes WHITE screen, already done replaced with new lvds cable still the same issue, replaced with new screen same issue, i have check on the schematic the LCDVCC is missing on pin23 on lvds connector, and on U26 chip here is the voltages
    PIN1= 0V
    PIN2= 0V
    PIN3= 3.3V
    PIN4= 3.3V
    PIN5= 0V
    PIN6= 3.3V
    Noticed that the out the PIN1 Is the output of the chip because pin 2 and pin 5 is ground.does anyone help me on this to solved this problem please
    Remove U26 ic and measure voltages on all pins again after switching. If everything remains same then jumper pin6 to pin1(without the IC) and your problem is likely to be resolved.
    • String2016
      • Nov 2015
      • 2229
      • philippines
      thank you very much mcplslg123 , I removed the chip and jumper pin1 and pin 6 now its working fine
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Julian Bailey
        HP ProBook 445 G8 Battery not charging
        by Julian Bailey
        Hi all
        We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
        The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
        I have gone around the board with a MM and cant find anything
        Windows shows the battery fine,...
        10-11-2024, 10:34 AM
      • piernov
        Laptop battery charging circuit
        by piernov
        1. Some theory
        1.1. Introduction
        Almost every laptop has a charging circuit of some sort, that does a few things:
        • Manages switching between AC adapter and battery power
        • Manages battery charging and generates power rail to charge battery
        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
        • Narrow VDC (NVDC)
        Texas instrument has a nice overview of these technologies with some more details at https:...
        11-15-2020, 01:31 PM
      • kodox
        ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
        by kodox
        since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
        the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
        what i've done:
        - flashing...
        12-29-2024, 02:49 AM
      • Shinju
        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
        by Shinju
        Hey All!
        Long time forum member here with a problematic laptop issue!
        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
        The laptop would not power on with the new battery installed without the power supply being plugged in.
        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
        10-20-2021, 04:58 PM
