Asus P302L x302la
  • lordgeny
    • Apr 2016
    • 223
    • Italia
    Asus P302L x302la
    Laptop not charging , not powering up .
    this two mosfet in the schematics are pea28ba, but i have another mosfet ,, i maked pics with voltage on it
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus P302L x302la
    The 1st Fet is not passing the 19V output check for short the 2 Fets with the help of the Multimeter. Try to find the Boardview file or make a Request in Bios Section
    Check the pea28ba fet not correct number
    • lordgeny
      • Apr 2016
      • 223
      • Italia
      i will check i need to find the right name of this mosfet
      • lordgeny
        • Apr 2016
        • 223
        • Italia
        i removed the 2 fet
        • lordgeny
          • Apr 2016
          • 223
          • Italia
          from other post found on forum
          A5 GNA = A5 GND
          marking significant "A5" P0903BEA. Everything else - the date, lot, ...
          N-MOSFET P0903BEA - AON7408 & FDMC8884
          but my one is a5 gne
          • lordgeny
            • Apr 2016
            • 223
            • Italia
            replaced with aon7408 i have again 0.90
            • Techtiger
              • Oct 2014
              • 1602
              • france
              Originally posted by lordgeny
              i removed the 2 fet
              those 2 Fets are N-Channel thats why gate need 24V to by pass the voltage to the 2nd fet you can replace with any N-Channel 30V one
              • lordgeny
                • Apr 2016
                • 223
                • Italia
                Fixed with 7408 from donor board. At first try was not solder corrected. Thanks
                • AppleLover123
                  Asus X712EA 3 volts after the first mosfet
                  by AppleLover123
                  Hey guys,
                  i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                  I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                  Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                  I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                  Now i thought something...
                  12-15-2024, 07:49 AM
                • Scotchmist
                  Asus GA502D keeps blowing mosfet
                  by Scotchmist
                  I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                  I have removed the mosfet and can run the laptop no problem
                  The MOSFET is FDPC5018SG
                  Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                  08-24-2024, 02:23 PM
                • MicroSMD Lab
                  ASUS ROG Zephyrus GPU Mosfet repeat failure
                  by MicroSMD Lab
                  The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                  I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                  01-10-2024, 06:36 AM
                • Timp74
                  Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
                  by Timp74
                  Hi All,
                  Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
                  I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
                  08-13-2021, 01:11 PM
                  ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                  This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
                  09-07-2024, 02:50 AM
