Toshiba A200-17O black screen. LA-3481 (BIOS or reflow ?)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I hope I'm not breaking any rules by not posting in the BIOS section, since this is also a generic discussion alongside a BIOS request. A friend asked me to have a look at this laptop which no longer turns on: it's a Toshiba A200-17O, probably some german model as far as I can tell since it points me to the german support site of Toshiba. See the picture of the label for the exact model. It powers up fine, and by that I mean all the power rails seem to come on, except there's no image on screen - classic failed graphics chip I though. The motherboard is a LA-3481P and it's got a pretty complicated setup: you got your CPU, a separate LE82PM965 graphics chip, an Intel NH82801HBM northbridge and a dedicated graphics card add-on, a LS-3481. I removed this last card and hit the Radeon GPU that's on it with some hot air (though without any flux) using my newly acquired soldering station hoping that would at least get it going enough to tell me that the graphics chip is indeed what failed - usually this works on most laptops. Now I'm not sure if I didn't use enough heat (not being thoroughly familiar with this new station) or the chip itself is dead or this is simply not the problem, because it didn't change anything...I tried the same procedure with the main board and the other 2 chips, but the same thing happened: black screen. If anything, now the laptop was shutting down after a few seconds since it was overheated. Another thing I noticed is that the NH82801 chip which I assume is the northbridge had some signs of flux around it, so perhaps someone reballed or reflown it before...not sure...
    Should I persevere with the graphics card and some flux or should I attempt a BIOS flash ? I have a programmer and I THINK I managed to locate the 24c16W1 IC which is the EEPROM, but I would require a BIOS for THIS model, as I couldn't find one exactly and I'm not sure how cross-compatible they are. I found some for LA-3841p boards in general, but not the exact model. Any ideas are welcome, like some people might recognize the board and the issue and point me in the right direction. No NEC-TOKIN on this board as I was expecting, unfortunately. Thank you.
    Wattevah...
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Toshiba A200-17O black screen. LA-3481 (BIOS or reflow ?)
    NH82801 chip is southbridge. LE82PM965 is your northbridge. To me it seems GPU issue as this laptop is quite old but bios should be tried first.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3588
      • slovakia
      offcourse it is those ATI GPU HD2600. have it on some my own laptops. it is always failing. it can withstand few reflows but after that it completly fail. but with reball it can work for much than a few months
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Blasted the GPU with some flux this time - no change: still turns off after a couple of seconds...attempting same procedure with NB. Either that, or one of the chips is dead - not just coming off the solder balls...
        Wattevah...
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          UPDATE: same problem with NB - no change even after "reflow". BIOS is up next...couldn't find anything exact like I said, so I hope one for PSAE6E is enough and what comes next is not important.
          Another thing I noticed is that this laptop has a small mPCIe 1GB SSD which I assume holds something like an "Express OS" for immediate startup for multimedia stuff and I did all these tests without it...I doubt it's relevant, but thought I'd mention this anyway just in case someone thinks otherwise...
          Wattevah...
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Seems like gpu has completely failed. Was the gpu heated earlier also?Any traces of flux around gpu? If you dont intend to replace the gpu, then its a loss of time investing on this mobo.
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              No, no signs of previous reflow. It even had that red wax still present at the chip's corners.
              Yeah, obviously not going to bother replacing the GPU - too expensive and not worth it...
              Wattevah...
              • mitchw
                HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
                by mitchw
                Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
                After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
                After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
                I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
                04-29-2025, 03:45 PM
              • BlueNitesFire
                I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                by BlueNitesFire
                So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                03-08-2025, 03:49 PM
              • Technodoc
                ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
                by Technodoc
                Asus laptop G614JZ-N3012W Rog Strix with i7
                Mainboard G634J-PMV-VGT
                6050A3441302-MB-A01
                2023-02-10
                Power button works okay....power light goes on
                Red "bottom" leds go on
                Charging led works
                Fans do not spin, capslock key does nothing, screen stays black
                I would like to program the bios again, to rule out a corrupted bios.
                However I run into a size error
                The bios chip is a Winbond 25R256JVEN
                Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                02-24-2025, 04:46 AM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • zenius
                by zenius
                12-08-2024, 06:13 AM
