Clevo N150SD powers on for 10 secs
  • Johndill
    • Aug 2015
    • 314
    Re: Clevo N150SD powers on for 10 secs
    Originally posted by piernov
    You are using a known good DDR3L RAM stick right?
    If it still has VCore but is not POSTing, you can probe BIOS CS# pin with the oscilloscope and LPC bus too (on LFRAME#) to see if there's any activity but it won't help much anyway. It can be almost anything, EC, PCH, CPU, maybe GPU, random stuff going on somewhere…
    I'd try another known good BIOS.
    Yes, I'm using a known good DDR3L RAM stick, I have even tried a second known good DDR3L RAM stick with no difference.
    I don't have an oscilloscope for that.
    Could I try a basic reflow with my SMD gun on one of the main chips?
    I haven't been able to find any bios for this model apart from the one linked by SMDflea that I have tried.
    • dellxps15
      • Feb 2014
      • 1588
      • italy
      #42
      voltage on u20 and u22 after pressing power on?
      • Johndill
        • Aug 2015
        • 314
        Tested and working from page 1 in post #3.
          • 20855
          This board uses DDR3 1.5V RAM doesn`t it ?
          • Johndill
            • Aug 2015
            • 314
            Same result with 1.5V DDR3 and 1.35V DDR3L.
            • Johndill
              • Aug 2015
              • 314
              What should I do next?
              • Johndill
                • Aug 2015
                • 314
                Anyone have any ideas?
                • Johndill
                  • Aug 2015
                  • 314
                  Is this the end of the road? Anyone?
                    • 20855
                    Do you have a Compal POST card, or a scope
                    • Johndill
                      • Aug 2015
                      • 314
                      I don't have ether, the post card sounds good, is there any particular post card I should get?
                      • Johndill
                        • Aug 2015
                        • 314
                        I put 3.3V to pin3 & 5 of U10 and the GPU started to warm up so I assume it was powered on but same issue happened.
                        I put some pressure down on the CPU and the CPU fan started working as it never did before but no boot, I heated up the CPU with the heat gun and now the CPU has no Vcore so I assume the CPU is probably dead.
                        • Chivo77
                          DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                          by Chivo77
                          hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                          1- After receiving power SIO_SLP_S0# goes high and never changes.
                          2-every...
                          07-03-2025, 09:20 AM
                        • dicky96
                          RTX 3080 Ventus 10GB OC - powers on for 10 secs then off again
                          by dicky96
                          Hey guys has anyone come across this fault?
                          MSI RTX 3080 Ventus 16GB OC
                          The GPU powers up, all voltages look OK, Vcore 0.76V, Vmem 1.38V, PEX 0.95V
                          Then after about 10 secs or so all voltages power back down again apart from 5V and 1.8V.
                          It does not seem to be temperature related - if I power off and on immediately, it just does the same thing again
                          I have a power sequence chart that says another voltage powers up after 1.8V and before PEX . It could be MSVDD but I am not totally sure
                          Does anyone have a schematic...
                          01-28-2022, 11:55 AM
                        • narf
                          Epson EB-U42 projector / Caps with 0.7 ohms ?!
                          by narf
                          hi all,
                          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                          what i've found so far:
                          - the PSU does its job and supplies 12V to the mainboard via the connector.
                          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                          - not far away, there's the first cap with a resistance of 0.7 ohms....
                          07-02-2024, 03:53 PM
                        • Günter Schuch
                          searching for Schematics & Boardview for Clevo P641HK1
                          by Günter Schuch
                          hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                          Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                          05-14-2025, 06:34 AM
                        • peterwang
                          CLEVO PCB:6-71-V2500-D02
                          by peterwang
                          Hi! I encountered a Clevo brand laptop that needed its boot LOGO modified. I found the LOGO address, but after the modification, the machine stopped displaying it. I'm puzzled. It worked normally before the 11th generation of CPUs, but it stopped working from the 12th generation onwards! The LOGO addresses are:
                          166BACEC-6793-4F38-213F-DE0BEF4FEF95
                          166BACEC-6793-4F38-213F-DE0BEF4FEF97
                          166BACEC-6793-4F38-213F-DE0BEF4FEF99
                          I have provided the BIOS and LOGO files that require LOGO modification, and I hope someone can help me.
                          post moved...next time look for a thread...
                          07-05-2025, 03:57 AM
