Clevo N150SD powers on for 10 secs
  • Johndill
    • Aug 2015
    • 314
    Hi, I have a Clevo N150SD, its power (white LED) light comes on for about 10 seconds then goes back to standby (orange LED) light.
    CPU Vcore is 1.69V, PL1 & PL2 coils.
    PL9, PL10 & PL7 have no voltage.
    I have found 3.3V & 5V voltages on the board so I assume those rails are working.
    CPU heats up, GPU stays cold.
    What should I check next? Thanks
    Schematics attached, their half way through the PDF
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Clevo N150SD powers on for 10 secs
    Did you try with a working Bios ? for PL9 PL10 PL7 test Diode mode Multimeter for Ohms
    PL12 1 PL13 Coil 3&5V test Diode mode Multimeter for Ohms
    PL11 1.35V
    VDDQ VTT 0.75VS ?
    V CORE ?
    U20 pin 8 or 9 3V ?
    U22 pin 8 or 9 5V ?
    RTC VCC ?
    RTC RST ?
    • Johndill
      • Aug 2015
      • 314
      Originally posted by techtiger
      Did you try with a working Bios ? for PL9 PL10 PL7 test Diode mode Multimeter Ohms
      I unfortunately do not have a flasher for the bios chip. Is there a way to flash from USB?
      I am unsure how to test with diode mode as I am still learning the trade. :-)
      Ohms to ground:
      PL7 - 46 Ohms
      PL9 - 10.3 Ohms
      PL10 - 10.3 Ohms
      PL12 - 5.22V
      PL13 - 3.29V
      PL11 - 1.35V
      VDDQ VTT? PU3 pin 24 - 0.67V
      VCORE? PL1 & PL2 - 1.69V
      U20 pin 8 & 9 - 3V
      U22 pin 8 & 9 - 5V
      RTC VCC? D8 pin 3 - quickly jumping up & down from roughly 1.18V to 60mV & up again
      RTC RST? I'm not sure where to test this one sorry
      • Techtiger
        • Oct 2014
        • 1602
        • france
        Ohms to ground:
        PL7 - 46 Ohms
        PL9 - 10.3 Ohms
        PL10 - 10.3 Ohms
        PL12 - 5.22V
        PL13 - 3.29V
        PL11 - 1.35V
        U20 pin 8 & 9 - 3V
        U22 pin 8 & 9 - 5V
        the voltages & the ohms Readings seems to be fine
        PL12 & 13 Ohms Reading?
        VDDQ VTT 0.75VS ?
        V CORE ?
        RTC VCC ?
        RTC RST ?
        you must buy a Bios Flashing tool with the Cilp so no need to remove the Bios chip every time from Ebay ect less than 15AUD
        yes i have seen Bios flashing VIA USB with a another Lap and a Secial tool Raspberry Pi
        • Johndill
          • Aug 2015
          • 314
          VDDQ VTT 0.75VS ?
          V CORE ?
          RTC VCC ?
          RTC RST ?
          PL12 - 32kohm
          PL13 - 2.3kohm
          Others edited in previous post.
          This one?
          https://www.ebay.com.au/itm/AU-EEPRO...4AAOSwuFZcd0zB
          • Techtiger
            • Oct 2014
            • 1602
            • france
            EPZ2010 PZ2013 CH341A
            • Johndill
              • Aug 2015
              • 314
              Thanks, I found a CH341A with a clip on ebay in my previous post so I'll get that one. 🙂
                • 21823
                Those clips don`t work very well with the CH341A. Best to desolder the bios if you can, or get a better programmer if you intend to repair more laptops in future. A good choice is the RT809F ,TL866II, RT809H .
                • Johndill
                  • Aug 2015
                  • 314
                  I've ordered a CH341A with the clip, if I have issues I can desolder the bios no worries, I don't usually come across bios issues very often
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    Even the "better" programmers won't work well with SOIC clips… I stopped trying and I desolder the chip everytime. (even providing external power doesn't help in some cases)
                    If you have VCore and PLTRST# then next is indeed trying to flash the BIOS.
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      i agree Piernov some Mobs you must desolder the chip
                      "RTC VCC? D8 pin 3 - quickly jumping up & down from roughly 1.18V to 60mV & up again" it should be 3.3V
                      voltage in D8 pin 1 2 3 shold be 3.3V piernov?
                        • 21823
                        I agree too, even with genuine pomono clips and external power it doesn`t always work.I own 2 of the green pcb version CH341A`s .
                        • Johndill
                          • Aug 2015
                          • 314
                          You are correct, my mistake, D8 was on the other side of the board & all pins are 3.3V.
                          • Johndill
                            • Aug 2015
                            • 314
                            My CH341A has finally arrived, where can I find a working bios to flash to the board?
                              • 21823
                              https://repo.palkeo.com/clevo-mirror/N1xxSD/
                              Second and fourth link up from the bottom of page, ec and bios .
                              EDIT: https://winraid.level1techs.com/t/gu...rammer/32948/3
                              • Johndill
                                • Aug 2015
                                • 314
                                Bios is backed up, erased and flashed.
                                What is the EC and what do I do with it?
                                  • 21823
                                  The EC controls the fan speed.You can make a USB bootable DOS drive,and include the files from the EC folder ,boot from it and run flash.bat ,the instructions are included. https://rufus.ie/
                                  Is the board booting up now since the bios flash ?
                                  • Johndill
                                    • Aug 2015
                                    • 314
                                    Ah ok, just tried now as I was waiting for your reply, unfortunately there is no difference than before, GPU fan spins a little and stops then after a few seconds power light goes back to standby
                                      • 21823
                                      Can you post both your bios backups ,U17 and U18 .
                                      • Johndill
                                        • Aug 2015
                                        • 314
                                        Ah, I only worked with U17 BIOS ROM, Attached, bios1
                                        What is ME ROM U18? Just dumped & attached, bios2U18
                                        • Chivo77
                                          DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                                          by Chivo77
                                          hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                                          1- After receiving power SIO_SLP_S0# goes high and never changes.
                                          2-every...
                                          07-03-2025, 09:20 AM
                                        • dicky96
                                          RTX 3080 Ventus 10GB OC - powers on for 10 secs then off again
                                          by dicky96
                                          Hey guys has anyone come across this fault?
                                          MSI RTX 3080 Ventus 16GB OC
                                          The GPU powers up, all voltages look OK, Vcore 0.76V, Vmem 1.38V, PEX 0.95V
                                          Then after about 10 secs or so all voltages power back down again apart from 5V and 1.8V.
                                          It does not seem to be temperature related - if I power off and on immediately, it just does the same thing again
                                          I have a power sequence chart that says another voltage powers up after 1.8V and before PEX . It could be MSVDD but I am not totally sure
                                          Does anyone have a schematic...
                                          01-28-2022, 11:55 AM
                                        • narf
                                          Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                          by narf
                                          hi all,
                                          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                          what i've found so far:
                                          - the PSU does its job and supplies 12V to the mainboard via the connector.
                                          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                          - not far away, there's the first cap with a resistance of 0.7 ohms....
                                          07-02-2024, 03:53 PM
                                        • Günter Schuch
                                          searching for Schematics & Boardview for Clevo P641HK1
                                          by Günter Schuch
                                          hallo leute ich habe ein problem mit meinem laptop der marke Schenker XMG P407 und zwar ist mir anscheinend der Grafikchip gtx 1050ti der direkt auf dem motherboard verlötet ist kaputt gegangen sie ist im Gerätemanager nicht mehr aufgelistet. deshalb hoffe ich hier unterlagen für das gerät zu finden. soweit ich herausgefunden habe wird die Platine die bei der firma Schenker verbaut wird von Clevo gefertigt und zwar mit der bezeichnung "Clevo P641HK1" ich hoffe auf eure hilfe und bedanke mich.
                                          Hello folks I have a problem with my laptop of the Schenker XMG P407 brand...
                                          05-14-2025, 06:34 AM
                                          Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic
                                          Axioo NEON MNW / Clevo W760S / Clevo W765S Laptop Schematic...
                                          10-04-2024, 03:59 AM
