Asus x55a no power or bootup
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi guys got this laptop in for repair wont boot or nothing i got the schematic for it and did some voltage checks and i have only 3.1 v on the first coil after the main power supply i have attached a picture with all the power supplies.. Can anybody point me on what steps to take next to trace the problem or what process to check next ..Thanks
    Your never to old to learn
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Asus x55a no power or bootup
    in the boardview, find PU8100. then measure voltage on all its pins to find out which one is wrong.
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Hi Caspian thanks for your reply the boardview i have do not match the motherboard i have
      i will check tomorrow and find it on the motherboard and let you know thanks
      • garrymc123
        • Apr 2010
        • 336
        • United Kingdom
        is this PU8100 charging ic
        • brew99
          • Jan 2019
          • 132
          What are the markings on that chip? I can't see anything in the photo
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            its bq25a
            • brew99
              • Jan 2019
              • 132
              That is probably it
              http://www.ti.com/lit/ds/symlink/bq24725a.pdf
              • garrymc123
                • Apr 2010
                • 336
                • United Kingdom
                ok here are the voltages for bq25a
                vcc 18.76
                phase 3.1
                hidrv 3.1
                btst 5.5
                regn 6.0
                lod 0.0
                gnd
                srp 3.1
                srn 3.1
                bati 3.1
                ilim 0.8
                scl 3.2
                sda 3.2
                iout 0.0
                acdet 2.5
                ac ok 3.0
                ac drv 25.02
                smcsrc 19.04
                acp 19.02
                acn 19.01
                Thanks guys
                • brew99
                  • Jan 2019
                  • 132
                  In your first post you mentioned that you have the schematic? Do you also have boardview? Can you post that here for us to look at?
                  I'm just an hobbyist starting out in this stuff, but the voltages on the BQ24725a look fine to me. VCC,REGN, ACDET, ACOK all there. I'm assuming that the ACOK is being pulled to a 3V rail, and not suppose to be some other rail?
                  • piernov
                    • Jan 2016
                    • 4436
                    • France
                    B+ rail is present so nothing to troubleshoot around charger IC, it's working fine.
                    Time to check the LDO outputs of the 3V/5V regulator.
                    • garrymc123
                      • Apr 2010
                      • 336
                      • United Kingdom
                      Thanks, Brew and Piernov I couldn't get a schematic it was the wrong one I got a board view link but it also was wrong. I have attached a pic is this the 3v/5v regulator area
                      • on/off
                        • Oct 2016
                        • 333
                        • Indonesia
                        Seem totally match with boardview from links provide by SMDFlea.
                        • garrymc123
                          • Apr 2010
                          • 336
                          • United Kingdom
                          I couldn't open that file with the boardview software i have its a fz file its usually a ASC file . What software do i require for the fz file thanks ON/Off
                          • on/off
                            • Oct 2016
                            • 333
                            • Indonesia
                            Open it with:
                            http://boardviewer.net/index
                            or
                            https://openboardview.org/
                            • garrymc123
                              • Apr 2010
                              • 336
                              • United Kingdom
                              Thanks guys for the help much appreciated with the laptop got the boardview working piernov where exactly can i find the outputs of the 3V/5V regulator Thanks
                              • garrymc123
                                • Apr 2010
                                • 336
                                • United Kingdom
                                Anyone??
                                • brew99
                                  • Jan 2019
                                  • 132
                                  I can't open a boardview file while I'm at work, but usually its a 20 pin or so chip. On my Asus X541UA machine the 3V/5V is a RichTek RT8249C, although I don't believe it was labelled that on the chip (looking back at prior docs I downloading for fixing it!).
                                  Can you indicate the markings on some of the 20 pin chips that you think might be, and we can go from there? Should be a couple of coils and FETS near it
                                  • brew99
                                    • Jan 2019
                                    • 132
                                    It's PU8100 on the other side of the PCB in the corner. It's an RT8206 chip, 32 pins
                                    https://www.richtek.com/assets/produ...S8206LM-07.pdf
                                    The previous chip you were looking at (BQ25a) was the charger IC.
                                    Look at the linked datasheet and measure outputs (use the boardview and search for PU8100)
                                    • garrymc123
                                      • Apr 2010
                                      • 336
                                      • United Kingdom
                                      Cheers brew99 i will measure voltages and get back to you with the results.
                                      • garrymc123
                                        • Apr 2010
                                        • 336
                                        • United Kingdom
                                        Right here are the measurements for the power management chip
                                        1 ref - 2v
                                        2 ton- 0.0v
                                        3 vcc - 5v
                                        4 enldo- 06.39
                                        5 nc - 0.0v
                                        6 vin -19.25
                                        7 ldo - 5v
                                        8 nc - 0.0v
                                        9 byp - 0.0v
                                        10 vout1 - 0.0v
                                        11 fb1 - 0.0v
                                        12 ilim1 - 1.816v
                                        13 pgood1 0.0v
                                        14 en1 - 03.1v
                                        15 ugate - 0.0v
                                        16 phase1 - 0.0v
                                        17- boot1 - 4.2v
                                        18 - lgate1 0.0v
                                        19 - pvcc - 5v
                                        20 - secfb - 0.0v
                                        21 - gnd
                                        22 - gnd
                                        23 - lgate2 - 0.0v
                                        24 - boot2 - 4.5v
                                        25 - phase2 - 0.0v
                                        26 - ugate2 - 0.0v
                                        27 - en2 - 0.0v
                                        28 - pgood2 - 0.0v
                                        29 - skip - 0.0v
                                        30 - vout2 - 0.0v
                                        31 - ilim2 - 1.3v
                                        32 - fb2 - 0.0v
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
