Asus X555LD no video on onboad display
  • A1yn88
    • Mar 2014
    • 112
    • Romania
    Hello.
    I have a problem with an Asus X555LD rev. 3.3. It has video only on external monitor. I changed the LDVS tape, the screen, I put another BIOS. When I try to change the display on the keyboard I only show my external monitor, as if the internal monitor did not exist. I do not know if it makes sense to do a CPU reflow or has other problems.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus X555LD no video on onboad display
    https://www.badcaps.net/forum/showth...ht=Asus+X555LD
    Downlode the Bordview and find the LDVS section find out what Voltage are missing 19v 3.3? For example
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      just a suggestion. some laptops have lcd display switch in the cmos setting try it first. reflowing the cpu will kill it specially if you don't have the proper bga reflow machine and tools. the CPU and Video ic is fine don't messed it up. just check the LVDS or place the original LVDS with the new screen make sure to put out the battery and power before connecting it. and try again..
      Never stop LEARNING because life never stops TEACHING!
      • A1yn88
        • Mar 2014
        • 112
        • Romania
        Hello
        Thank you for the answers.
        I have boardview for v. 2.0 because for v. 3.3 I have not found, but I think are the same with regard to the location of the pins on the display. I have 19V and 3.3V. I have checked with LDVS and three-source display, including new products.
        • A1yn88
          • Mar 2014
          • 112
          • Romania
          Hello guys, I solved the problem. The bad piece on the motherboard was ANX1121. It was stranger to be diagnosed because I was taking out all the values indicated on the boardview, but it had some internal resistance, I suspect, that failed. The luck was that an identical laptop came in service with other problems and I was able to compare it. I do not know what happened exactly but the screen was defective too.
          • pecrie
            • Nov 2011
            • 182
            @A1yn88 ,
            I just had a good look at the X555LD schematic in the TSIC boardvieuw.I don't have that much experience with using boardvieuw until now.
            But I have noticed several indications for some objects /parts on the pcb.
            For some it says PRxxxx - does it means Part Resistor (PRxxxx) ?
            Others are named PJxxxx - for Part Jumper ?
            And PCxxxx for Part Connector ?
            Is my assumption correct ?
            And I could not find the 19Volt in the NET list .
            Just playing around with the boardvieuw I can see that it is a heck of a tool to find problems or voltages at certain locations
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3592
              • slovakia
              tsic is piece of crap
              • Techtiger
                • Oct 2014
                • 1602
                • france
                Originally posted by pecrie
                @A1yn88 ,
                PRXXX Resistor
                PCxxxx capacitor
                PJ for Jumper
                at the beginning boardvieuw are difficult but with experience it's easy
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3592
                  • slovakia
                  Have exactly the same problem on X553MA. did u have some measurement that prove that ANX1121 is bad, or u just replace it? Mine LCD look like bad too
                  • A1yn88
                    • Mar 2014
                    • 112
                    • Romania
                    When I tested with multimeter on diod, showed 0.040 on + 3V circuit and 0.004 circuit on + 1.2V circuit, and on the other board that I had as a reference shows about 0.387 on the same electrical circuits.
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      test J4502 voltage
                      pin 2 3 4 36 38 39
                      your +3VS line is bad find the starting point of +3VS you have to trace it from there
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3592
                        • slovakia
                        Originally posted by techtiger
                        test J4502 voltage
                        pin 2 3 4 36 38 39
                        allready checked - all ok. even all signals have its voltages
                        display not react, but when i connect known good lcd, its backlicht blink abou half a seconds period
                        • pecrie
                          • Nov 2011
                          • 182
                          @techtiger thanks for the explanation
                          • Conste
                            • Oct 2018
                            • 235
                            Also had this problem before, defective ANX 1121 chip.
