HP Elitebook 8740W - How to trick ADP_EN with aftermarket charger?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Hello.
    Have this HP Elitebook 8740W that wont start with not original adapter. How to trick ADP_EN with aftermarket charger? i dont want to jumping signals. Anybody know if they used some ic for charger detecting like dell or some resistor to middle pin?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP Elitebook 8740W - How to trick ADP_EN with aftermarket charger?
    100k resistor from dc+ to middle pin... easy mod to do on charger side
    Im Back... sort of...
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3622
      • slovakia
      thanks mate. worked like a charm
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3622
        • slovakia
        any body know value of resistor for HP Charger for hp 15 laptops with blue connector end ?
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          Same story for HP blue connector with center pin (4.5x3.0)
          You can use 330K resistor between DC+ and center pin=90W.
          Become a Badcaps supporter
          Thanks to all supporters.​
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3622
            • slovakia
            thanks mate. i use 300K because i dont have 330K but it works anyway
            • openminded
              • Apr 2017
              • 73
              • home
              useful list : https://www.parkytowers.me.uk/thin/hp/hp_psu.shtml
              • motormayhem
                Lenovo T460 Only Charges on One Charger
                by motormayhem
                Laptop Question
                I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                05-12-2023, 01:46 PM
              • ktmmotocross
                How to trick Apple Macbook Pro to work with aftermarket charger :-)
                by ktmmotocross
                Hello.
                Again need to trick some laptop to work with aftermarket charger. Now it is apple. I have apple charger, but it is broken, so how to trick aftermarket charger to work with original apple cable?
                02-28-2019, 06:07 AM
                NVDC charger configuration...
                11-05-2024, 03:28 PM
              • flat-earther
                how to prevent a connected charger from draining battery when not charging?
                by flat-earther
                I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                So the battery is backfeeding the charger and being drained.
                How can I prevent...
                08-07-2025, 01:04 PM
              • flat-earther
                ASUS X54H laptop thinks it's always charging even with charger unplugged
                by flat-earther
                The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                Windows also shows ''Plugged in'' when charger is not connected.
                This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                If I let battery run out and say it has 3% Windows will...
                06-24-2025, 09:32 AM
