K1126
  • frankkrantz
    • Feb 2019
    • 12
    K1126
    K1126ic
    Does anyone know what this component is please, i canot find a data sheet/schematic for it at all..
    I think it may be power supply to usb 5v.
    Kind Regards
    Frank Krantz
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: K1126
    I guess US1 is probably an AND gate and DM2 is probably an array of Diodes. you can use the datasheet of MC74VHC1G08 for US1.
    • Lee M.
      LG 55LN5710 backlight diffuser sheet order
      by Lee M.
      Hello all, new member here. I replaced the LED strips and found that the BL can be turned on with the TCON board and LCD panel disconnected. So new LED strips are working fine. Now the problem. There are 3 diffuser sheets on this set. One sheet is thicker than the others and I know it goes in first next to the LED strips. But one side of this sheet has a rougher texture than the other side. Does the rough side go up or down? The 2 thinner sheets have tabs that will only allow them to be installed one way so that's good. One sheet is what I would call plain translucent. The other sheet is whiter...
      11-29-2021, 07:52 PM
    • lfhlaw
      60LN5600 white reflective sheet
      by lfhlaw
      So I had to replace the LED lights on this TV and that worked out nicely. But the White reflector sheet that helps to diffuse the led lights evenly was glued into the back chassis which had to be removed to replace the LEDs.
      Placing the white reflector sheet caused it to not sit evenly - causing weird diffusing when TV was all put together. Picture is still decent, but now there are dark and light spots due to the white reflector sheet not sitting against the back chassis.
      Anyone have thoughts on replacement white reflector? or do I just scavenge broken TVs for...
      05-23-2022, 07:14 PM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Topcat
      Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
      by Topcat
      This was rescued from a recycle gaylord from a hospital along with some other things....
      I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
      Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
      08-02-2023, 10:07 PM
      TOP201YAI 3-Terminal TO-220 PWM switch Figure #7 in date sheet
      by sam_sam_sam
      I would like to know what the specifications for the transformer in this data sheet is I would like to build one
      Also for figure number 8 as well
      Also for figure number 9 as well
      Here is the data sheet I know that this item has been disconnected but I can buy them surplus
      https://cdn.badcaps-static.com/pdfs/...da43fe7f6c.pdf
      I have a mad scientist streak in me lately and want to be a little adventurous
      The reason is I have some ATX switching power supply that I have as spare parts from and wondering if I could use one...
      10-09-2021, 06:21 AM
