Cedar_Intel -MB RSMRST# signal not generating............
  • abdul0853
    • Mar 2015
    • 8
    • India
    Hi all brothers,
    I have a problem with my motherboard DRAMRST# signal not generating
    I checked all requirements of ram and everything found okay
    I tried to jumper that too with 1.35V but it didn't worked
    please guide me
    Motherboard Model number is
    Cedar_Intel -MB
    13269-1
    PWB FX3MC REV : A00
  • mdashlam@123
    • Mar 2019
    • India
    Re: RSMRST# signal not generating............
    first of all you need to check your clock generator ic is working fine or not. check clock enable which comes from core ic
    • James Mi
      • Aug 2020
      • 30
      • Ecuador
      Colleague excuse me I just started to repair equipment, where do I find the IC VCORE?
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        @james mi
        Vcore is the voltage supply to the processor core. Depending on the type of motherboard there is usually one controller IC driving various phases (MOSFETs and sometimes MOSFET driver IC's) that generate Vcore. There could be up to 8 phases, often there are four or six phases but it depends on old the board is. Generally newer boards have more phases. If you want to measure Vcore look for some inductors around the CPU and measure there.
        If you want to find the Vcore controller IC it is usually a QFP or QFN type chip somewhere in that area, probably 48 pin. If you look for that type of IC near the CPU and look up the datasheet for the part number you should be able to find the Vcore IC quite easily
        The other easy way is if you can find the schematic or board view for your motherboard
        Follow me on YouTube
        Learn Electronics Repair
        • James Mi
          • Aug 2020
          • 30
          • Ecuador
          Thanks Friend!
          • AstutePauciloquent
            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
            by AstutePauciloquent
            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
            11-23-2023, 11:02 PM
          • Fernon@Repair
            MSI mpg b560m bazooka motherboard RSMRST# signal missing
            by Fernon@Repair
            I have MSI mpg b560m bazooka motherboard . this motherboard RSMRST# signal missing . i already reprogram bios but same condition
            My Motherboard this power stages are ok ...but 3vsb voltage have 4.17v (image added)
            VCCRTC ok
            RTCRST# ok
            ATX_5VSB ok
            SIO_3VA ok
            3VDSW ok
            DPWROK ok
            SLP_SUS# ok
            VSB_ENABLE# ok
            5VDUAL ok
            3VSB showing 4.17V
            PCH_1P8_VSB ok
            PCH_VCCIN_AUX ok
            RSMRST# No voltage
            this all voltages are ok but RSMRST# voltage is missing i did try to re program bios and change io but same...
            06-03-2025, 10:49 AM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • JayPoorJay
            Converting +/- 5v to a Usable Hz Signal
            by JayPoorJay
            Good morning.
            I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
            This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
            The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
            08-07-2022, 08:35 AM
