help finding a compatible mosfet to AON6962 ?
  • Weelcup
    TopTech
    • Oct 2017
    • 302
    HI friends
    I am struggling to find a compatible mosfet to the one i have ...
    mine is AON6962
    Is AON6992 compatible?
    thanks in advance
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3588
    • slovakia
    Re: help finding a compatible mosfet to AON6962 ?
    found only 6992 datasheet
    https://cdn.badcaps-static.com/pdfs/...6d15cfea78.pdf
    but u read that 6962 is n-channel so it is compatible
    find if u have q1 or q2 6992, because q2 is more than 2times stronger
    • Weelcup
      TopTech
      • Oct 2017
      • 302
      Thanks a lot for following up.
      Q1 or q2 ? I didn't really get that. Will appreciate if you can explain a bit what that refer to.
      Otherwise yes it is n-channel...
      Thanks again
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3588
        • slovakia
        look at schematic. i think q1 or q2 is marking of ic
        for what circuit u want it?
        100A pulsed is enough for everything except hi power CPU or GPU
        • Weelcup
          TopTech
          • Oct 2017
          • 302
          But unfortunately there is no schematics. It is for dell G5.
          It is for the GPU circuit. However, there are two mosfets feeding the same line. So yes I suppose it is over 100A feeding line but it is divided between the two mosfets.
          By the way the GPU is nvidia GTX 1050 4GB....
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3588
            • slovakia
            thats bad. that kind of gpu requires good mosfet. what is complete marking on that 6992 u have?
            check if it is a lowside or high side mosfet. lowside mosfet can be weaker so u can use that
            • Weelcup
              TopTech
              • Oct 2017
              • 302
              the AON6992 mosfet is also feeding the 1050 GTX GPUs but in earlier versions of dell laptops. specifically in dell inspiron 7567 ... that is why I was thinking if it might match. but if there was a little difference in the amount of ampers between 6962 and 6992 then would it make a problem to use 6962&6992 to feed the same line without conflict between them....
              of course i prefer 6962 but i cant find it online to buy .. only they are available in lots not singles...
              thanks
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3588
                • slovakia
                put it there as a lowside and u r good
                • Weelcup
                  TopTech
                  • Oct 2017
                  • 302
                  thanks … I will check it...
                  • Weelcup
                    TopTech
                    • Oct 2017
                    • 302
                    it worked ... thanks for your help....
                    • morino
                      • May 2021
                      • philippines
                      Good day I would like to ask my Laptop is a Dell G7 mosfet is not working. The mosfet for the GPU 1050ti model is 6962 GA8T1C. thank you. for your help!
                      • mon2
                        • Dec 2019
                        • 14120
                        https://m.aliexpress.com/i/33010651095.html
                        • granadav6
                          • Sep 2013
                          • Bulgaria
                          There is no lowside since it`s double transistor.It`s high and low side in one chip.
                          • hamza1997
                            • Mar 2022
                            • Pakistan
                            Originally posted by Weelcup
                            HI friends
                            mine is AON6962
                            thanks in advance
                            Hello Everyone!
                            My laptop Dell G3 is also having same problem and my computer mechanic said that they need AON6962, AON6992 and ISL95522 IC to repair it. But unfortunately these are not available in Pakistan.
                            I want to know if I source it from abroad, will my problem be solved?
                            Thankyou!
                            • mon2
                              • Dec 2019
                              • 14120
                              Post the full details of your logic board so we can review the schematics.
                              Are you able to source parts from China (Aliexpress) ?
                              With the crazy state of hot heads in the world, know that India banned sourcing from China. Not sure if you have a similar ban.
                              It is possible to sub these parts but need to review the schematic for your unit to be safe.
                              More later after some beauty rest.
                              • Jane
                                How do you test MOSFET in laptops ?
                                by Jane
                                I tried to use this method:
                                Testing an N-channel MOSFET:
                                Step 1: Discharge the Gate (turn off the MOSFET)
                                Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                Step 2: Charge the Gate (turn on the MOSFET)
                                Now, place the red probe on the Gate (G) and the black probe on the
                                09-27-2024, 03:31 AM
                              • Blastsail
                                Help find compatible MOSFET from Asus FA506 DABXBMBAD0
                                by Blastsail
                                I have a coffee damaged asus laptop with shorted mosfet for vram. Trying to find replacement but I am struggling to. Markings are M3966M and I have attached image of mosfet. Schematics are available which say chip is a QM3966M6 but i am unable to find this chip no matter what combination of letters i put in. I can see there exists an m3966m3 chip but this appears to be the wrong size and markings are different.
                                I have attached schematic as well to help, mosfet is on page 44 of pdf. I do not know where to start to find a compatible mosfet so any help will be greatly appreciated....
                                05-07-2022, 07:35 AM
                              • Peeripapo
                                Finding a compatible USB Thunderbolt 3 port for this Asus g752vt board
                                by Peeripapo
                                Hi All,
                                so I got an Asus g752vt and the USB C (Thunderbolt) port is broken. I need to find a compatible replacement for that.
                                Are all USB C conectors the same or do I need to get a specific one for that board. The USB port brand is LOTES and it has the 1546 number on top of it. Where can I Find a similar one ?
                                [COLOR=hsl(var(--text-300)/var(--tw-text-opacity))]
                                [/COLOR]...
                                04-30-2025, 09:37 AM
                              • Nooy
                                VGA MOSfet permanently shorted and loss of MOSfet pad
                                by Nooy
                                Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                02-14-2024, 02:26 AM
                              • AppleLover123
                                Asus X712EA 3 volts after the first mosfet
                                by AppleLover123
                                Hey guys,
                                i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                Now i thought something...
                                12-15-2024, 07:49 AM
