the U25 Chip starts to heat up when the power button is pressed but no response the pin 6 VTT3_VCCP_PWROK is not present what maybe the cause of this problem is it bios problem?
PETRONAS-14 REV 1.4 wont power up
Tags: None
Re: PETRONAS-14 REV 1.4 wont power up
pin 6 VTT3_VCCP_PWROK this is a Switching power only it comes in S0 state off in S3-S5
check if you have P12.0V ALW ?
U11 pin 65 RSMRST# ? you dident answer
test U11 pin 8 for 3.3V
U11 VCC1PIN 14 VCC2 PIN 49 FOR 3.3VLast edited by Techtiger; 02-07-2019, 02:33 AM.Comment
I dont have p12.0v_alw i only have 3v on r459
ULL PIN 65 NO VOLTAGEComment
my misstake not pin 8 of U11 that's pin 65 & 64 for 3.3V, no Voltage in pin 65 Mob will not pass S3 state , 12V is missing test c1019 or R381 for 12V i cannot find the starting point of the 12V Rail may be anothe member can help IT SHOULD COME FROM PAGE 40 OF SCHEMATICLast edited by Techtiger; 02-08-2019, 02:36 AM.Comment
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by MJ8051Hello guys,
I need some advice how to proceed in trying to repair my ASUS Vivo Book S400C Laptop.
It was working fine until, I accidentally let it fall due to unstable position at some outdoor Access Control Terminal Setup connected to LAN port, while in operation.
But, luckily, the Top left metal corner cover of the LCD display get a small dent. and the Laptop works again.
Until now, when I press the POWER push switch, I didn't TURNED ON , even trying with the AC Charger plugged in or on battery only.
The exact same situation already... -
This specification for the HP Pavilion Power Pavilion Power 15-cb009nl Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 15-cb009nl boardview and Pavilion Power 15-cb009nl schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:59 AM
by sikocanDell Vostro 5490
Service Tag: G8T7NW2
Motherboard Model: Mantis CML 18778-1
Schematics: Attached in the Google Drive folder.
BRD File: Attached in the Google Drive folder.
Video of the issue: https://youtu.be/bIXaiiub664 (Also on Google Drive)
Google Drive link: https://drive.google.com/drive/folde...j_?usp=sharing
I've attached Resistance Readings at 200ohms range. Voltage Readings, with and without power button being pressed. Detailed board pictures. Old and new BIOS files attached.
... - Loading...
