Macbook A1502 2015 kernel panic
  • Gimi
    • Aug 2015
    • 75
    Hi everyone, I have this apple logic board 820-4924A and have done apple hardware test with no faults, also did memtest full test and no memory faults.
    no water damage no repairs to the board.
    i can install the os but every so often it will reboot and show kernel panic.
    Any idea or anyone has ever had this problem and any help if possible? Thanks
  • sofles
    Macbook Pro 16" A2141 screen artefacts, kernel panic
    by sofles
    Hi there.
    I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
    I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
    Now situation looks like this, If...
    02-05-2025, 05:05 AM
  • prw07
    MacBook Pro A2141 - macOS Kernel Panic
    by prw07
    Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
    How to localize the problem ?
    12-05-2023, 06:57 AM
  • Wachenaggo
    Macbook Air 2013 820-3437 OSx Frozen and Kernel Panic Missing ME
    by Wachenaggo
    I got 2013 820-3437 that can't boot completely onto OSx and can load EFI ASD BUT can't on OS ASD and it gives this kernel panic error FAILURE missing ME. I already check ME disable strap HDA_SDOUT_R is low
    Also before I reflash the bios I was able to boot osx 10.9 maverick SSD from another client. But when I install a fresh maverick it is frozen.
    I already reflash bios using ch341 with clean me provided by piernov and 2informaticos then I even make my own using piernov's guide. some of those BIOS are boot looping the system.
    I also manage to damage...
    03-29-2022, 07:36 AM
  • backes
    Macbook Pro 2015 A1502 SSD apparently died
    by backes
    My macbook pro froze, and now I get the folder with question mark symbol. In the recovery mode the SSD can't be found in the disk utils. I then used a Linux USB stick to try to mount the SSD and it wasn't present in `lsblk` . Which led me to the conclusion that the SSD itself is broken. I then gave it to apple support and they say that the SSD is dead and wanted to replace it for around 400€. I declined this "repair".
    Then I bought a new SSD from amazon for 70€, however also this one doesn't work and can't be found in disk utils in the recovery...
    01-10-2022, 09:52 AM
  • duwane
    KB and Trackpad only work in safe mode - 820-4924-A Macbook Pro Late 2015 A1502
    by duwane
    Hi all. I hope someone has come across something similar, as I am baffled.
    I have a faulty logic board from a 2015 A1502 Macbook Pro Retina (820-4924-A). Some signs of liquid, but all corrosion cleaned, and several components refloated or replaced to eliminate any visually corroded areas of the board.
    Machine boots fine now, but the keyboard and trackpad do not work at all when booting normally into Catalina, Big Sur, or Monterey. At the login screen, the cursor does not move at all when moving on the trackpad, and no keys on the keyboard respond on screen, however...
    04-11-2022, 08:49 PM
