Macbook air 13inch a1466 emc2632
  • alihomee
    • Dec 2012
    • 1574
    • malaysia
    Display comes like this as shown in pic......tested with another working screen but same any ideas from where to start....motherboard is clean no waterdamage
  • Gimi
    • Aug 2015
    • 75
    Re: Macbook air 13inch a1466 emc2632
    Check cpu voltage. if 0v then your cpu can have a short
    • mosfetratus
      Sure Not
      • Feb 2019
      • 174
      • Resistron
      Do you hear macbook jingle? Even without a screen, you should hear a boot sound.
      • alihomee
        • Dec 2012
        • 1574
        • malaysia
        no sound nothing
        • mosfetratus
          Sure Not
          • Feb 2019
          • 174
          • Resistron
          faulty RAM?
          If you had hardware error with OK ram, you should hear beeping codes.
          No chime, no beep. I think simple RAM reflow could fix that. But don't jump into my conclusion.
          • alihomee
            • Dec 2012
            • 1574
            • malaysia
            i did try that by reflow ram chips but no luck
            • piernov
              • Jan 2016
              • 4435
              • France
              PRAM reset done? Display OK on external (with internal disconnected)?
              • alihomee
                • Dec 2012
                • 1574
                • malaysia
                yes but still same
                • Akinovich
                  • Aug 2017
                  • 8
                  • The Netherlands
                  USB mouse light up?
                  CPUVCORE voltage?
                  • alihomee
                    • Dec 2012
                    • 1574
                    • malaysia
                    yes if connect external ssd with usb it lights up but no communication ...i mean usually when mobo reads it the light blinks but in this cause no blink
                    • alihomee
                      • Dec 2012
                      • 1574
                      • malaysia
                      vcore is good and cpu also gets hot
                      • Akinovich
                        • Aug 2017
                        • 8
                        • The Netherlands
                        Interesting never seen this before. You have no chime so I would check around U1950 and check around the bios. Measure pins of bios in diode mode. Spi rom resistors traces and bad bios are usually the cases for me in with these weird problems
                        • alihomee
                          • Dec 2012
                          • 1574
                          • malaysia
                          tried with a working bios file but still same condition
