compaq 6510b chaging issue
  • akande
    • Dec 2017
    • 278
    • Nigeria
    i have compaq 6510b that will not power on with charger but can work fine with a charged batt, little check done q507- s=19v, d=17.5, d=0v pls kindly guide me to fix the fault
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: compaq 6510b chaging issue
    Check the Voltage in U5 8.9.26.5.29.22.4.27
    check the Voltage in Q539 pin 1.2.3 & D12 pin1.2
    Check your Adapter 90W
    Check U14 pin 74 ADP_PRES
    • akande
      • Dec 2017
      • 278
      • Nigeria
      q539 pin 1,2,3=18.0v d12=17.8v
      u5 pin8, 9.26.5.29.22.4.27 =0v
      pin 74 = 0v
      • Techtiger
        • Oct 2014
        • 1602
        • france
        DC jack pin 3 LIMIT_SIGNAL ? Q507 pin4 Gate Voltage is to high 18V to bypass it should be less than 10V , test Q507 for any short G/D/S
        • akande
          • Dec 2017
          • 278
          • Nigeria
          q507 not short but g=17v
          • Techtiger
            • Oct 2014
            • 1602
            • france
            DC jack pin 3 LIMIT_SIGNAL ? Test Q514 for any short as well
            • akande
              • Dec 2017
              • 278
              • Nigeria
              LIMIT_SIGNAL trace to q22 S=5.6V, D=0V, G=0V
              Q514 NOT SHORT
              • Techtiger
                • Oct 2014
                • 1602
                • france
                remove Q507 put the multimeter Diode mode value S.D.G
                test all pins of Q545
                • akande
                  • Dec 2017
                  • 278
                  • Nigeria
                  q507 removed S=18.2V, G17.6V D=0V
                  Q545 B=16v C&E=0V
                  • smali
                    • Sep 2014
                    • 287
                    • Pakistan
                    Check u6(lm393)
                    • akande
                      • Dec 2017
                      • 278
                      • Nigeria
                      Originally posted by smali
                      Check u6(lm393)
                      THANKS BRO AFTER REPLACING U6, all seem ok but still not coming up , i found out there is short pin 19 of u28. i replace c336, remove use u28 but short remain plz
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3628
                        • slovakia
                        thats bad. +V3AL is on many lines. try to inject voltage to find bad component faster
                        • smali
                          • Sep 2014
                          • 287
                          • Pakistan
                          follow the ktmmotocross insturction inject external 3v with high amps on the short line and observe the pcb the faulty component will be heatup....i think your smsc kb1070 may be faulty...
                          • akande
                            • Dec 2017
                            • 278
                            • Nigeria
                            after injecting my u14 become very hot
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3628
                              • slovakia
                              NO HIGH AMPS!!!
                              with 3V put max 2A =6W and rise it if u cannot find component. if u put 5 or higher amps u can burn component and WELDING COMPONENTS LEG TO PAD which is way harder to repair
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3628
                                • slovakia
                                remove it and check if short is gone. than measure its pads for short to check if it have internal short or some of its output is shorted
                                  HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                  This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                  09-12-2024, 03:44 PM
                                  HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                  This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                  This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                  09-12-2024, 03:36 PM
                                  HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                  This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                  09-12-2024, 03:30 PM
                                  HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                  This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
